introducing my srt4 and some Qs on it
Old Jun 8, 2011 | 01:52 AM
djomlas's Avatar
djomlas
Default introducing my srt4 and some Qs on it
hey guys, just got this beast.
from what i can tell, the resonator has been removed, and the exhaust dumps right after the axle...has a short throw shifter and intake, oil catch can, and some sort of fuel management.
i tried to figure out if the wastegate is stock, but not sure since i havent been around these cars for a while (coming from wrx, porsche, ls1s, minis....)
thing is...it boosts up to 21psi. that CANT be stock by any means. pulls like a train trough all the gears tho. anything that i can check?
possibly mopar ecu? i dunno....
i did not find a boost controller hooked up anywhere, so what gives?
here is a picture of the car and one of the engine bay, can anyone spot anything else that i am not seeing?
thx in advance
Old Jun 9, 2011 | 02:53 PM
Moparmatt440's Avatar
Moparmatt440
From the pics it looks like a AGP waste gate, if it is it will have the name on it. With a upgraded spring they will hold 21 no problem. Your return line set up is also from AGP. Does the turbo houseing have MOPAR on it around the area where the intake goes on? Thanks what I can see from the pic
Old Jun 9, 2011 | 03:41 PM
djomlas's Avatar
djomlas
thanks for the reply.
i looked at this site when you mentioned agp wastegate.
http://www.modernperformance.com/blo...9-caliber-srt4
looks just like it, but no name engraved, maybe some batch didn't come w engraving? but looks just like it tho.
Old Jun 10, 2011 | 02:54 PM
Moparmatt440
Well it could be on the bottom, if the person before you put the better spring in could have rotated the top part. Have fun it, they are a fun car
Old Jun 10, 2011 | 04:40 PM
djomlas's Avatar
djomlas
thanks for the reply, i really dont feel like crawling under it to see if its engraved in there, im sure its upside down haha.
i also checked, it has stage 2 injectors as well, so not too shabby...no wonder this thing pulls as it does.
Old Jun 15, 2011 | 08:48 PM
Moparmatt440
you might have a full stage 2 set up on it, does your MAP sensor have a 3 bar on it? Do you have a red and blue button inside the car next to the aux outlet under the radio?
Old Jun 16, 2011 | 10:16 PM
djomlas's Avatar
djomlas
thanks guys...
i got a small mirror, and sure enough begind the wg, its engraved mopar..
as far as map sensor, how do you tell the 3 bar thing? would it just say there or? and yeah, def nothing inside the cabin, i looked up on the web and i see what youre talking about, but not it.
Old Jun 21, 2011 | 06:30 PM
Moparmatt440
Some do have 3 bar on it. As far as the Mopar, if it were a stage 3 turbo it would have Mopar on the out side on the turbo inlet housing. You can also try and look at your pcm and see if it has a stage number on it
Old Jun 24, 2011 | 11:32 AM
djomlas's Avatar
djomlas
yup, after a bit more research and part number lookups, its a 3 bar! figures, since stock one couldnt handle that much psi for sure.
i also just lowered the car with some meganracing springs, nothing fancy, but killed the gap pretty good and cost me nothing since i sold the stock springs for same as i got the lowering ones for. i got bunch of new tools, so wanted to see if the install will go faster than usual wrenching, and took about 2 1/2 hrs....mainly trying to get that damn top bolt off the strut, but worked out ok w powertools .
i also got some modern performance halo headlights that i need to wire up, and took off crappy tint job on the windows, and tail/3rd brake lights....
but here is a picture of the car as it sits now, springs settled a bit more now, but nothing too far from this
Old Jun 27, 2011 | 11:59 PM
Moparmatt440
Looks good, I had those projectors on my srt, loved them especially with 8000k HIDs
