launch
Old Jul 18, 2005 | 09:52 PM
rhart's Avatar
rhart
Default launch
I have an 05 srt4 with the stage 3 and cat back exhaust, I am having a heck of a time launching. I have 18 inch wheels and tires. Sat nite got smoked by a trans am because of launch. Any ideas? Don"t like losing!!!
Old Jul 18, 2005 | 10:04 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: launch
start from a roll...but I dont see how youd lose to a t/a w/ stage 3...t/a s only do 13.1 in a quarter. You should be in the 12s...try racing from a 20mph roll. Other then that lose the 18s and do 15s w/ drag tires. Practice your launches as well. If you have a practice tree you can help w/ your reaction time too. Best of luck!!
Old Jul 18, 2005 | 10:59 PM
roachnigga's Avatar
roachnigga
Default RE: launch
Flutter ya clutch in 1st gear: shift @ 3500k's. Powershift @ 4700-5200 @ second then go for broke all the way home
Old Jul 19, 2005 | 01:30 AM
PSI Chick's Avatar
PSI Chick
Default RE: launch
no need to shift that early. shift at like 5500 on the street, you'll be fine. don't let off the gas either
Old Jul 19, 2005 | 03:15 PM
TRAV's Avatar
TRAV
Default RE: launch
Hey Highrevver, pretty hard to start from a roll at the track
Old Jul 19, 2005 | 03:20 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: launch
ORIGINAL: TRAV
Wouldn't that be nice.
Staging would be prety tough, though.
Old Jul 19, 2005 | 04:04 PM
TRAV's Avatar
TRAV
Default RE: launch
I HEAR YA
Old Jul 19, 2005 | 04:31 PM
RIPSIGUY's Avatar
RIPSIGUY
Default RE: launch
I had good luck with lowering tire pressure and doing a smokey burn-out before launching. The tires seemed to spin much smoother after a ghood burnout.
Old Jul 19, 2005 | 05:27 PM
roachnigga's Avatar
roachnigga
Default RE: launch
the reason i shift in that range, is because i notice that its a little harder to throw to 3rd ranging @ 5500-6000k. Causing miss shift. Maybe its my car... that my sweet spot. Hey, Rhart, if 5500 works then there it is. No Offense, Psi... One
