How do you do this?
Old Aug 4, 2005 | 04:20 PM
Gotturb0's Avatar
Gotturb0
Default How do you do this?
i got this picture off cardomain. i was wondering if anyone knew how to do this? How do you put the middle part of the bumper inward?
Old Aug 4, 2005 | 04:41 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: How do you do this?
Most likely, it was cut out and redone with fiberglass. Some bumpers are pre-molded that way. Others are custom modified with fiberglass. It looks like it was cut out, recessed, fiberglassed, and then primered and painted.
Old Aug 4, 2005 | 04:52 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
EDIT-i was wasnt even looking at the right thing...i apologize...
Old Aug 4, 2005 | 05:01 PM
DevilsReject
Noob Assassin
I agree BadStrat. Like I said, its either a pre-molded kit, or its a custom job.
Old Aug 4, 2005 | 05:26 PM
posthondaremoval's Avatar
posthondaremoval
Guys, no kit, or fabrication is necessary - that is a stock bumper that has been rolled.
It is very easy to do, and many have done it. Up close, I don't lke the look as muck, personally, but if I did a side exit I might consider.
All you do is pull the strap at the bottom of the bumper up a bit higher and re-attach it. see the following:
http://www.srtforums.com/forums/show...ghlight=bumper
Also note - once it is rolled - you need to keep it rolled, - you will deform/crease the bumper.
Old Aug 4, 2005 | 05:50 PM
LilSparkPlug's Avatar
LilSparkPlug
Yeah upclose it exposes alot of the rear suspension and looks gaff to me. But from above it doesnt look all that bad. And with dual exit exhaust....[:'(]
Old Aug 4, 2005 | 07:25 PM
black4's Avatar
black4
has anyone seen an srt rear diffuser that turboneonstore.com sells on our cars and any performance benifits?
Old Aug 4, 2005 | 07:40 PM
posthondaremoval
Good ? I would like to know also - that thing looks pimp.
Old Aug 4, 2005 | 08:42 PM
MChat's Avatar
MChat
I did mine like that. It's really as simple as relocating the mounting strap things.
Old Aug 4, 2005 | 08:50 PM
roachnigga's Avatar
roachnigga
[sm=chattypair.gif][sm=youreright.gif]
