should the turbo blades look worn?
Old Aug 24, 2005 | 02:14 PM
S R T 4 M E's Avatar
S R T 4 M E
Default should the turbo blades look worn?
after taking my air intake off i noticed from what i could see that the turbo blades appeard to be worn. like a bit of dirt passed through the filter. is this normal? does the warranty cover the turbo and this kind of wear?
Old Aug 24, 2005 | 06:17 PM
dOmestIc_rIce's Avatar
dOmestIc_rIce
Default RE: should the turbo blades look worn?
ORIGINAL: S R T 4 M E
it should. Is the car stock. EG: no mopar cold induction?? It shouldn't look worn yet....how many miles on car??
Old Aug 24, 2005 | 06:24 PM
S R T 4 M E
the only thing i have done to the car is a intake system. but im not sure the filter is doing its job,obvously. i have 19000 on the car. its this going to be a big factor in the reliability of the car?????
Old Aug 24, 2005 | 06:54 PM
RIPSIGUY's Avatar
RIPSIGUY
As far as your air intake system goes, if you bought a quality filter it is doing it's job. I see alot of turbos here, mostly on Cummins engines, and the compressor blades ALWAYS have deposits on them. In fact, sometimes it will look like cracks on the turbine, but it is actually carbon or dirt. What ever you do, DO NOT try and clean them off. Solvents could attack the seal for the bearings, or you may bend/damage a blade trying to remove it.
Old Aug 25, 2005 | 01:19 AM
S R T 4 M E
i can see how carbon and other such things get on the blades, but do you see any turbos that are worn.(the blades that is)? it sorta looks as if someone sharpend them, like a kinfe.
Old Aug 25, 2005 | 01:21 AM
S R T 4 M E
does anyone know if a cold air intake will void turbo warranty???
Old Aug 25, 2005 | 12:43 PM
jameshushek's Avatar
jameshushek
if the cai does void it just put the stock back on
