choppy boost
Old Sep 5, 2005 | 01:39 PM
1fast04neon's Avatar
1fast04neon
Default choppy boost
i just put the s1 with a boost controller and im tring to run 17-19 lbs but i get a real choppy boost. just wondering if anybody has a forge motorsport wastegate and if that will help the problem. I was also thinking it could be the bottom intercoller pipe. would a pressure pipe help. and the last thing while im here does anybody have the eibach 1.6 / 1.8 springs, i was wondering how they ride ( i couldn't resist a deal) so i ordered them already.
thanks alot
Old Sep 6, 2005 | 03:26 AM
Hi N Mity's Avatar
Hi N Mity
Default RE: choppy boost
my boost was cutting out and stuttering, I started to open up the gap on the spark plugs from .42.....got to .52 and everything was smooth again. i heard that you need to narrow the gap when you start to add HP, and stay around .50 when stock.
Old Sep 6, 2005 | 10:46 PM
1fast04neon
so u were opening the gap and i should close it?? do u have any other mods?
Old Sep 6, 2005 | 11:39 PM
wyze's Avatar
wyze
yo, dude i think the problem is that you are running to much boost. and yes a new wastegate would help. and second it also depends on what kind of boost controller you have. manual(turbo xs) or electric(greddy or blitz,apex i, etc.)? if its an electric then you have to mess around with it. well actually if its either or you still have to play with it (haha play with it) in order to get a good response, but an electric is a little bit more difficult to use if you dont know what you are doing. i had the same problem when i had,when i had, a Greddy profec spec 2. i think it was anything above 16 it would bog out.
Old Sep 6, 2005 | 11:57 PM
1fast04neon
yea even low amounts of boost (w/ the manual controller) are choppy. do u kno how hard it is to put the wastegate in?
Old Sep 7, 2005 | 01:35 AM
Hi N Mity's Avatar
Hi N Mity
i would think that s1, you probably wouldnt change the plug gap from the stock gap....but I was thinking that if you had changed the gap previous, you might want to change it back and see what happens.
Old Sep 7, 2005 | 08:56 PM
1fast04neon
i havent changed it yet
Old Sep 7, 2005 | 11:24 PM
black4's Avatar
black4
everyone keeps messing with those boost controlers which what ive seen so far for a lot of people are nothing but trouble but to each his own.[sm=chattypair.gif][sm=confused06.gif]
Old Sep 16, 2005 | 03:23 AM
SRT_BDK's Avatar
SRT_BDK
ya i had the same problem be boosting 15 the pop down to ten and pop up to 12 all over the place
took it in and found out it was one of the spark plugs misfiring..hope that helps
