DENSO Plugs????
Old Sep 18, 2005 | 10:47 PM
MYSRT4's Avatar
MYSRT4
Default DENSO Plugs????
I was thinking of putting denso in my 03 SRT and i was thinking i would ask all ya all what you thought and if they are a good idea what part # is it right noe i have NGK @.38
Old Sep 18, 2005 | 11:34 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: DENSO Plugs ????????????????????????
depends on your cars setup. There are a couple heat ranges. What do you have going on under the hood?
But ---- definitely go for Denso's...They are worth every penny. Sparkplugs.com is a very good place to go. Call them if you have ?'s they will steer you right. If you have specific ?'s I could see if I could talk to Brian over @ denso to get good answers for you.
The heat shielded wires they sell are a great investment, too.
Old Sep 19, 2005 | 02:39 AM
MYSRT4's Avatar
MYSRT4
ORIGINAL: posthondaremoval
This is what i am runnin @ the moment
Stage 3 w/toy
clutch master stage 3 clutch
eibach sport kit 1.6 front 1.8 rear
spearco monster IC
Iceman 60mm TB"GARBAGE" need to get new one any suggestions
Iceman CAI"Garbage" AEM CAI on the way
Snows Water injection
MSD coil
msd wires
NGK plugs .38
Atp uppipe w/HKS ssbv
MPX 3"turbo back W/cat should the cat stay on or come off?????????
MM inserts/ Avid MM on the way
if there is anything you see that i dont have that i need to get more power let me know and i will buy it also i need advise on rubber for the track what will fit with my eibach kit never been to the track yet so i am a track rookie
Old Sep 19, 2005 | 03:15 AM
PSI Chick's Avatar
PSI Chick
you have a very similar set up to what i have. i'm running denso ITV22's, and using the assigned gap. it's working out perfectly for me.
Old Sep 19, 2005 | 04:57 AM
posthondaremoval
ORIGINAL: PSI Chick
Nice setup, MySRT4
I agree with your assessment, PSI Chick. Spot on.
I would generally recomend the ITL series, just because the ITV req's. a special socket to install/remove(i know - you can take a std. socket and grind it down). In this case the ITV is correct because of the fact that the heat range on the ITV22 is a step colder than is available in the ITL series. ITV22 ought to do it.
Old Sep 19, 2005 | 11:45 AM
PSI Chick's Avatar
PSI Chick
yup, that's why i have the ITV's. the ITL's are easier, but don't come cold enough. i also have the 9mm high temp wires.
i've found that these plugs and wires are great, no blow out, no studder, smoother idle, and i'm not changing them every 3 months like i was with the ngk's.
Old Sep 19, 2005 | 11:57 PM
MYSRT4's Avatar
MYSRT4
ORIGINAL: PSI Chick
so would you recomend that i change from msd 8.5 mm wires to a 9mm high temp w/ denso itv22 plugs
Old Sep 20, 2005 | 12:36 AM
PSI Chick's Avatar
PSI Chick
if you get an ITV series plug than you have to get the wires from denso as regular wires will not fit. the ITL series can use a normal plug wire.
Old Sep 20, 2005 | 02:58 AM
MYSRT4's Avatar
MYSRT4
ORIGINAL: PSI Chick
i went to sparkplugs.com and they did not have the itv series only itl16 so where do i go to get wachoo got sparkplugs.com has packages w/wires so where do i go to get the ITV plugs cause i wantm
Old Sep 20, 2005 | 03:23 AM
PSI Chick's Avatar
PSI Chick
call them and ask for the itv22 plugs and wires. they are listed in their computers as for the pt cruiser last time i ordered, not sure if they ever changed that.
