k&n drop in hp gains?
Old Sep 22, 2005 | 10:59 PM
srt4 kid's Avatar
srt4 kid
Default k&n drop in hp gains?
I installed the k&n drop in filter today and I was wondering what kind of hp gains i can expect. I know the gain won't be ground breaking but the k&n has got to be better than the stock filter. The reason i'm asking is because it has been raining today and the conditions haven't been right for wot so i haven't been able to see for myself. Thanks
Old Sep 23, 2005 | 11:48 AM
srt4 driver's Avatar
srt4 driver
Default RE: k&n drop in hp gains?
Where did you buy that filter / how much / does it fit into stock air box and what Part# is it? I am thinking about picking one up if you could help.. I have one on my motorcycle and the gas mileage seems to have improved since installation about a month ago.
I currently had the Fram "AirHog" in my car and noticed no diffrence betwee it and the stock filter.
Thanks Man..
Heres some info from K&N's website
K&N’s lifetime replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. We make over 1,200 different replacement air filters for virtually every vehicle on the road. These filters are custom designed to fit into your existing factory air box. Their drop-in design means adding performance is simple. Simply remove the disposable air filter and replace it with a K&N; there is NEVER any cutting or fitting required. Our stock replacement air filters for street vehicles are covered by our famous K&N Million-Mile Limited Warranty™ and will be THE LAST AIR FILTER YOUR VEHICLE WILL EVER NEED. [MORE]
E-1006 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 5.375 in (137 mm)
Flange Inside Diameter: 2.5 in (64 mm)
Flange Length: 0.75 in (19 mm)
Flange Type: Centered
Height: 5.875 in (149 mm)
Top Outside Diameter: 5.5 in (140 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.33 oz (39 ml)
Weight: 1.5 lb (0.7 kg)
Product Box Length: 6.44 in (163 mm)
Product Box Width: 6.38 in (162 mm)
Product Box Height: 7.13 in (181 mm)
AND THEN
57-1535 Product Specifications
Product Style: 57 Series FIPK
Estimated Horsepower Gain: 9.84 HP @ 5500 RPM
Type: Gen II
Replacement Filter: RP-4660
CARB EO Number: D-269-28
Weight: 11.1 lb (5 kg)
Product Box Length: 22 in (559 mm)
Product Box Width: 14 in (356 mm)
Product Box Height: 12 in (305 mm)
Old Sep 23, 2005 | 11:54 AM
srt4 driver
I would think just the K&N filter with the stock air intake would be about the same gains...
Old Sep 23, 2005 | 03:58 PM
SRT_YA's Avatar
SRT_YA
doubtful that you would feel any gains. it might be good for 5hp on a dyno in the right conditions...
I stick with K&N not for the power gains, but I watched a friend sink his truck practically and the filter helped save his motor from hydro-locking...
Old Sep 23, 2005 | 04:32 PM
Gump's Avatar
Gump
sorry srt_ya but the filter has nothing to do with hydro locking... since your friend got almost to the filter not to the filter or over the filter it doesnt matter. if you put a cai on with k&n filter and sink that filter and boost your going to turn that cai in to a straw... i use k&n so i can clean my filter as i please and every week if i want.
Old Sep 30, 2005 | 03:02 AM
posthondaremoval's Avatar
posthondaremoval
^^^and cleaning makes a big difference. Same here.
Ditto on the 5hp comment.
Old Oct 10, 2005 | 08:23 PM
AirWolf's Avatar
AirWolf
For my sxt adds a little horse power with my srt exhaust but mostly so much better gas mileage . K&N is the way to go to begin with then Im addin a typhoon cca red intake .
Old Apr 11, 2006 | 01:05 AM
zaksblaklabel's Avatar
zaksblaklabel
dropped a k&n in my stage 2, and noticed a slight difference in hp, but i also removed the filter box, and after that, noticed the turbo spools alot faster and sounds like its almost screaming at me now. i recommend it if you want a cheap addition in horse power. anyway, good luck
Old Jun 3, 2006 | 04:33 AM
FlakDodger's Avatar
FlakDodger
If I am not mistaken the K&N will flow almost twice the air a stock paper filter will.
Old Jul 10, 2006 | 05:59 PM
Back40's Avatar
Back40
Anyone concerned with the skeptical filtration issues as well as the possible damage to sensors (MAF, etc) due to the oil in the filter? I have read some pretty damning info lately, unfortunately after installing K&N air filters on my wife's and my vehicles.
