ngk iridium plugs or denso plugs?
Old Sep 25, 2005 | 02:08 PM
srt4 kid's Avatar
srt4 kid
Default ngk iridium plugs or denso plugs?
Which spark plugs would you guys recommend? NGK Iridiums or Densos? The plugs will eventually be used in conjunction with msd 8.5mm wires.
Old Sep 25, 2005 | 02:53 PM
PSI Chick's Avatar
PSI Chick
Default RE: ngk iridium plugs or denso plugs?
both are good plugs, you can't really go wrong with either ones.
Old Sep 30, 2005 | 03:00 AM
posthondaremoval's Avatar
posthondaremoval
^^^X2
I will say that the Denso's seem to last a bit longer for me.
Old Sep 30, 2005 | 08:53 PM
bigham's Avatar
bigham
so on a stock set up you would reccomend which one's and we plan on doing stage 2 at the end of the year
Old Oct 1, 2005 | 03:05 PM
PSI Chick's Avatar
PSI Chick
if you're planning on going stage 2 i would just get a set of regular ngk's and use those. then put in the irridiums when you upgrade later one. irridium plugs really shouldn't be gapped, they have a good chance of breaking, and as such you don't want to be messing with them. a stock car and s2 car need different gaps, as well as heat ranges.
Old Oct 1, 2005 | 06:22 PM
bigham's Avatar
bigham
any good sites for the ngk's pricewise or a part number and what should I gap it at or does it come gapped already
Old Oct 2, 2005 | 04:35 AM
posthondaremoval
ORIGINAL: bigham
Just get the ngk 4306's for this car from your dodge dealer. They are an alternative plug that they probably have in stock. sparkplugs.com has good prices and are very knowledgable, too. Just get stock heat range copper ngk v-powers, and you'll be set, and then, like PSI Chick said, if you go s2, get the iridiums. the above site also sells packages of denso + wires that are excellent and well heat shielded(good idea). If you are staying with the stock ecu, either iridium in stock heat range should be fine; I like denso's.
Old Oct 2, 2005 | 08:57 PM
bigham's Avatar
bigham
thanks for all the help
Old Oct 5, 2005 | 07:15 PM
Vettely's Avatar
Vettely
Soooo, which plugs, gap, heat range do you suggest for stg-1?
Old Oct 6, 2005 | 05:15 AM
posthondaremoval
Same as stock should be fine for s1. Really - it depends on what you have in addition to stage 1, as plug upgrades are more related to horsepower increases, and some have s1 pushing around 300 hp - in that case a stage colder might be advisable. Stage 1 and not more than intake and exhaust should be okay at stock heat ranges. Figure less than a 35 hp gain should be fine at stock range, 35-90 hp more should be a stage colder, 90 and more should be 2 stages colder(and these are not concrete numbers, just a vague idea to help put it in perspective).
