Some Changes coming...
Old Nov 14, 2005 | 12:51 PM
MChat's Avatar
MChat
Default Some Changes coming...
Just thought I'd share some of the changes I have planned for my car in the next few months.
This last weekend I installed the Mopar Stage 3R Coil-Overs with 450lb springs in the front and 350lb springs in the rear and the "helper" springs, which I believe take some of the harshness out of the ride (car still rides nice on the street).
I also picked up a set of "Skinny" drag wheels for the rear. They're the Bogart Fly-Stars. (Speaking of Bogart wheels, if anyone wants a set of Bogart wheels, let me know I have a contact at Bogart since they're local to me.) And the M&H 24x3.6" tires are on their way.
I'm hoping between the coil-overs and the skinnies to hit a 10 sec 1/4 mile this weekend. (Best time w/o the skinnies and coilovers is an 11.37)
Then next month, the car gets fitted with a 5pnt bar (w/ a removable swing out side bar) and Sparco Racing seats w/ 5pnt harnesses.
And here's the BIG change:
Hopefully the week after Christmas (if all the pieces come in on time) I'll be installing a fully built NRGY Race engine.
NRGY Race ported head
Crane Cams
Custom CP pistons
Crower Billet Steel Rods
MADI Crankshaft
Ceramic coated "everything"
W/ the new engine, I fully expect the car to be consistantly in the 10's... and then I'm going to add a 100shot DP Progressive Nitrous setup and see how deep into the 10's it'll go.
Old Nov 14, 2005 | 12:56 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: Some Changes coming...
Hot damn.
You got me all excited[sm=bounceybounce.gif]
Sounds awesome, man.
Old Nov 14, 2005 | 02:26 PM
LilSparkPlug's Avatar
LilSparkPlug
Dammmnnnnnnn happy in my pants on that one!!!! Latrodectus is Gasmic. Sounds like in due time youll be beyond the 10s! Good luck, let us know how it goes this weekend!
Old Nov 14, 2005 | 03:02 PM
coyoteyz13's Avatar
coyoteyz13
ORIGINAL: MChat
I don't think the swing out side bars are NHRA legal, but your car sound sick. you will be the first in the 10s. I think.
Old Nov 14, 2005 | 05:03 PM
MChat's Avatar
MChat
ORIGINAL: coyoteyz13
ORIGINAL: MChat
I likely won't be the first daily driven street SRT-4 in the 10's; that'll probably be my friend Chris's car... the NRGY built S3R car that ran an 11.114 Saturday night. But I hope to be a close 2nd.
Also the swing out side bars are permitted:
NHRA Regulations:
Swing-out side bar permitted on OEM full-bodied car, 7.50 e.t. and
slower. The following requirements (a through d) apply:
a. 1 5/8-inch O.D. x .083-inch CM or .118-inch MS minimum.
Bolts/pins must be 3/8-inch-diameter steel, minimum and in
double shear at both ends.
b. Male or female clevis(es) permitted. Male clevis must use two
minimum 1/8-inch-thick brackets (CM or MS) welded to each
roll-cage upright; female must use minimum 1/4-inch-thick
bracket (CM or MS) welded to each roll-cage upright. Pins must
be within 8 inches of the vertical portion of both the forward
and main hoops. A half-cup backing device must be welded to
the vertical portion of the main hoop (inward side) or the upper
end of the swing-out bar (outward side), minimum .118-inch
wall (CM or MS) extending at least 1 5/8 inches past the center
of the pins. A clevis assembly using a minimum .350-inch-thick
male component and two minimum .175-inch-thick female
components may use a 1/2-inch-diameter Grade 5 bolt and
does not require a half-cup backing device.
c. Sliding sleeves of 1 3/8-inch x .083 CM or .118 MS, with
minimum 2-inch engagement, are permitted in lieu of the upper
pin/cup.
d. All bolt/pin holes in the swing-out bar must have at least one
hole diameter of material around the outside of the hole.
Old Nov 14, 2005 | 05:25 PM
coyoteyz13's Avatar
coyoteyz13
ORIGINAL: MChat
ORIGINAL: MChat
NHRA Regulations:
pin/cup.
Woops. I guess I was wrong. Good luck hitting the 10s. Keep us posted.
Old Nov 14, 2005 | 05:56 PM
Andy4.7's Avatar
Andy4.7
Sounds like some fun!
Old Nov 15, 2005 | 04:37 AM
Pressurecooker's Avatar
Pressurecooker
Good luck!
Old Nov 15, 2005 | 09:02 PM
bigham's Avatar
bigham
get video for us to see
Old Nov 15, 2005 | 09:15 PM
turbeaux kid's Avatar
turbeaux kid
One word..... WOW
