Finally got it back
Old Dec 5, 2005 | 07:22 PM
srt4babe's Avatar
srt4babe
Default Finally got it back
Finally got my car back today, they had to replace the #21 fuse in the PCM. They said they had never seen that before. Has anyone else had this type of problem?
Old Dec 5, 2005 | 07:33 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Finally got it back
I haven't heard of that particular problem before, but I'm glad you got it taken care of and got your car back!![&:]
Dusty
Old Dec 6, 2005 | 03:03 AM
PSI Chick's Avatar
PSI Chick
isn't that the fuel pump fuse?
Old Dec 6, 2005 | 01:47 PM
srt4babe's Avatar
srt4babe
Not a clue
Old Dec 6, 2005 | 01:55 PM
PSI Chick's Avatar
PSI Chick
i'm pretty sure that it is. i did a quick search on this (as i haven't had this happen to me so i am not familiar with it) and it seems like once that fuse starts blowing, it keeps blowing because it's connected to the downstream o2 sensor and that usually is he souce of the problem. not sure why dodge did that, but whatever. basically just replacing the fuse probably isn't going to do it. i would definetly suggest getting a pack of yellow 20amp mini fuses and keep them with you in case it blows again.
Old Dec 6, 2005 | 03:23 PM
srt4babe's Avatar
srt4babe
If I take it back to Dodge, what should I tell them to replace to fix the entire problem?
Old Dec 6, 2005 | 04:07 PM
black4's Avatar
black4
never heard of this problem before interesting keep us updated how its going.[sm=confused06.gif]
Old Dec 6, 2005 | 05:39 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Sounds like they cured the symptom and not the cause itself. I'd carry some spare fuses and save the paperwork from the original
"fix" so you can take it back and get it fixed right if it happens again.....
Dusty
