New Engine parts starting to arrive...
Old Dec 6, 2005 | 10:38 PM
MChat's Avatar
MChat
Default New Engine parts starting to arrive...
:wub:
Old Dec 6, 2005 | 11:00 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: New Engine parts starting to arrive...
Looks sweet!!!!!!!!
Dusty
Old Dec 7, 2005 | 02:11 AM
chadsicle's Avatar
chadsicle
Very nice. How much will those pistons up your displacement?
Old Dec 7, 2005 | 02:45 AM
LowSlowNeon's Avatar
LowSlowNeon
So shiny and sweet.
Old Dec 7, 2005 | 06:44 AM
Pressurecooker's Avatar
Pressurecooker
I don't think he's going larger or much more than a standard overbore. That being said, an overbore of .030 (typical 1st over) will only net you about 3-4 cubic inches, which you could maybe then call a 2.5 liter. Wooo Hooo.
You never get much of an increase in displacement by boring.
Old Dec 7, 2005 | 11:51 AM
MChat's Avatar
MChat
Yea, these are .020" overbore. The engine block I have is so new, I actually thought about running std-bore pistons. Engine displacement will be 150ci or 2.457L vs 148ci or 2.429L stock. So I guess if you rounded up it *could* be called a 2.5L.
Old Dec 7, 2005 | 11:59 AM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Looks really good man. Glad to see you're getting her back up and running super sweet this time.
Old Dec 7, 2005 | 05:29 PM
posthondaremoval's Avatar
posthondaremoval
MMMMM....NICE...not trying to make a pass at ya' or nothing, but I am getting envious of your piston over here.
Can't wait to see what you got coming in next.
Nice concavity, btw - ought to be just the ticket for holding lots of boost with no bangy bangy.
Old Dec 9, 2005 | 01:23 AM
chadsicle's Avatar
chadsicle
Post noticed the same thing that I did. I thought the stock pistons were flat with a big ramp going across one side. If you remove the ramp and concave the piston it should give you quite a bit more displacement without having any overbore. Im sure you’re right about having a 2.457 displacement with the new pistons, it just seems to me like you should get almost 2ci per piston with all the material removed plus the .02” overbore. Im definitely no expert on the matter, just a little curious. Thanks for your posts! Also, is that a stock cam or did you get 2 new ones with longer duration?
Old Dec 9, 2005 | 01:48 AM
wordslayer's Avatar
wordslayer
Man,,that stuff looks great.
Now it makes sense to me why fish hit on those shiney lures.
