1st oil change
Old Apr 24, 2004 | 09:35 PM
Jackass's Avatar
Jackass
Default 1st oil change
Hey all, did the first oil change today 1900mi. the factory filter was a real pain in the ***, I had jam a screw driver in the filter to actuall turn it I broke 1 gripper before that. but its changed and the operation was successfull.
Old Apr 24, 2004 | 09:59 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: 1st oil change
I've heard that before about the factory installed filter being a real pain to take off. Must have a big, strong dude at the assembley plant puttin' them on...
Hopefully you put synthetic oil in it, right???[sm=smiley4.gif]
Old Apr 25, 2004 | 04:33 PM
Jackass's Avatar
Jackass
no I was told by my brother in law thats a mechanic that I shouldn't put synthetic in till after 15000 mi, so I put in castrol gtx
Old Apr 25, 2004 | 04:36 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
They come from the factory with synthetic and my Dodge dealer as well as the service advisor told me to use it. In addition, your owner's manual says to use Mobil 1....
Old Apr 25, 2004 | 08:53 PM
roachnigga's Avatar
roachnigga
GO WITH FULLY SYN.... ITS BEST FOR THE SYSTEM.
Old Apr 25, 2004 | 09:18 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
How's the weather in your part of Germany, Roach?
Old Apr 25, 2004 | 10:55 PM
roachnigga's Avatar
roachnigga
68-71 degrees on average... but, today there was snow.[:@]
Old Apr 25, 2004 | 11:27 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I can believe it. Boy, I hated being posted to guard a F-4 Phantom on the "hot pad" in the snow...no protection from the wind. Give me a defensive fire bunker or hole anytime...[&:]
Old Apr 26, 2004 | 03:00 AM
bigddy9's Avatar
bigddy9
Me too. My filter wrench was sliding but not turning the filter. It took me 2 hours to do a damn oil change. It was so tight down there could barely get my hand over the filter once I loosened it.
I bought one of those Pure One filters. I don't know if they are worth the extra $$$, anyone else tried one of those yet?
Danny
Old Apr 26, 2004 | 06:32 AM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: Jackass
The rule on synthetic oil use is not to use it on a new or rebuilt motor until it reaches 5,000 miles, this gives the motor sufficient break-in and lets everything seat properly. However, there are exceptions to every rule, the SRT-4 as well as many other high end cars like the Viper and the Z06, come from the factory with synthetic oil, most of these high end cars come with Mobil 1. Older engines were built looser, but todays engines are built to alot tighter tolerances and can use synthetic oils right off. I highly recommend that you use what the factory says to use for at least the 1st 5,000 miles, wether it's conventional or synthetic oil. Most cars come with conventional motor oil and should NOT be switched over to synthetic oil until it has at least 5,000 miles on it, but I highly recommend switching to synthetic after 5,000 miles. It will give you better gas mileage as well as better performance and lower wear and operating temperatures. If you have a car with high mileage or one that leaks or burns oil, do NOT use synthetic as it will only make the leaks or oil burning worse and it may cause leaks in a high mileage engine(it may not but thats up to you).[sm=smiley20.gif]
