Stage 2 initial impressions
Old Apr 29, 2004 | 01:54 AM
glhs837's Avatar
glhs837
Default RE: Stage 2 initial impressions
http://www.srtforums.com/forums/showthread.php?t=50047
Shows a complete list of tools, and tips. Here's the tool list.
T-20 and T-25 torx drivers
-3/4", 5/16", 3/32" drill bits
-hand drill and an electric drill
-you will also need something very skinny and at least 3.5" long (we used a 1/16" drill bit) to pierce and then clear the way for where the new wires enter the PCM connectors.
-wrenches and/or sockets: 10mm, 8mm, 13mm, 15mm
-snap ring pliers (optional, you can use your hands for this step)
-needle nose pliers
-philips and flat head screwdrivers
-exacto or wire splicers (I used an exacto when tapping into exisitng wires)
-coat hanger (would make fishing the wire thorugh the foot well much easier)
-electrical tape
-rags or towels (some fuel spills when depressurizing the system)
-soldering gun
-strong fingers
-spectacles, so you can see those damn tiny pin numbers and letters
the LEDs use the 5/16th, one of the easiest parts, they have fairly long leads, give you a choice.
Old Apr 29, 2004 | 09:45 AM
glhs837's Avatar
glhs837
About the fluid. And I quote from the install directions.
"NOTE: Distilled water is the recommended fluid for the intercooler sprayers. Use of the intercooler spray system is not recommended in driving conditions that warrant use of washer solvent."
Of course, I spray Rain-Xs winshield washer fluid, the orange stuff. Stufff is GREAT!!!!!!! But since I don't want to spray that on the intercooler, I'm going to rig an auxillary tank for the sprayers. Gotta get a small tank mounted, probably a coolant overflow tank of some kind. Til I hit the junkyard, the hose and wires are capped and stowed
Old May 1, 2004 | 07:13 AM
badsrt4's Avatar
badsrt4
What would be the difference in performance if i choose not to get the turbo toys for the 2nd stage?, and could i get them afterwards? because i heard that once you buy the kit w/o the toys you won't be able to purchase them.[X(]
Old May 2, 2004 | 04:01 AM
71RoadRunner's Avatar
71RoadRunner
The difference in performance is really only with the high octane switch, it allows more power with the use of 100 octane unleaded gasoline. With a tank full of 100 octane and a flip of the switch and you will go from Stage 2's 265 horsepower to 280 horsepower. That is correct, you cannot purchase and add toys later.
Old May 2, 2004 | 11:04 AM
glhs837's Avatar
glhs837
71RR,
While it's true that dynowise, the only differences are the 20hp bump for racegas, and a 5hp for the sprayer, that's dyno. Real world, Toys has the advantage of two selectable tristage boost settings. There's only a few S2s out there, but initial indications show it gives a good advantage in launch. I know theres a 94-96 Vette that can vouch for that Hope to hit the track today at MIR, if this misting clears.
Old May 2, 2004 | 03:36 PM
NU2ltSRT-4's Avatar
NU2ltSRT-4
This may sound like a silly question but I keep hearing about the 100 grade Octane and the switch for it. But does this kit come with a new tank for the 100 Octane? And if so how big is it? If it doesnt how exactly does that work?
Old May 3, 2004 | 06:52 AM
71RoadRunner
No additional tank, just the cars original fuel tank. You are supose to run out as much of the 91+ octane you normally use as possible, this way the slight amount 91+ octane thats left won't degrade the 100 octane much at all if any. Then you go to a gas station that carrys 100 octane gasoline and fill it up. When you have driven it for about 10-15 minutes all the lower grade 91+ octane gasoline should be out of the fuel lines and replaced with the 100 octane you just put in it. Now flip the high octane switch and have fun.[sm=smiley4.gif][sm=smiley2.gif]
Old May 3, 2004 | 03:42 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yeah, they want you to run it until the low fuel warnings come on.....then, hopefully, you'll be near a station that sells 100 octane....
Old May 3, 2004 | 04:11 PM
NU2ltSRT-4's Avatar
NU2ltSRT-4
Hey glhs837 when you said MIR did you Maryland International in Bowie, MD? I'm just wondering b/c I live in Calvert County and when I come home in the summer back to MD I am always up that way. I was wondering what you need to run your car there and when. I haven't run mine yet and am at 2200 miles and probably close to 3000 when I get to MD so I'm sure it will be plenty broken in.
Old May 3, 2004 | 05:16 PM
glhs837's Avatar
glhs837
Yep, I live about 25 minutes away, down by Pax River NAS. If you are runnig quicker than 14.0, you need a helmet. we've got about 6-8 SRTs here in St Mary's, at least 2-3 in Calvert, and Charles has a bunch, mostly centered on Andrews. where in Calvert, , one owner lives in Owings.
