Grease around the boots?
Old Dec 29, 2005 | 05:12 PM
turbeaux kid's Avatar
turbeaux kid
Default Grease around the boots?
I just dropped my car with the Tein springs. And I was wondering when you drop a car is it normal that there is grease coming out around the boot? It wasnt much grease but it is something that concerns me. Thanks for the help......
Old Dec 29, 2005 | 05:26 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: Grease around the boots?
ORIGINAL: turbeaux kid
Sounds like a blown cv or busted axle. do you hear a click at startup in first or when braking at low speed?
Old Dec 29, 2005 | 07:52 PM
turbeaux kid
No I dont hear that. It is only one side that blew. And I checked both sides and they feel like they are the same.
Old Dec 30, 2005 | 03:43 PM
posthondaremoval
I think I misread - you have a leak around the boot on the strut?
I thought you were talking about the cv boot for some reason...if that was the case:
It would only be one side. Still could be the cause.
But if it is a strut, it sounds like a busted seal, it'll progressively worsen, probably. Time for some tokiko 5 ways or something made to run at higher pressure(it's okay, though - you will like the improved dampening of a better setup). Just my .02.
Old Jan 2, 2006 | 01:57 PM
turbeaux kid
I went and had someone look at it for me and it is the cv boot. he said it will cost like $260 to fix it. does that price sound right??????
Old Jan 2, 2006 | 03:48 PM
posthondaremoval
Damn I'm good. I should've been a mechanic. Anywho - don't pay anything if you are still under warranty. Take it to a good dodge dealer and see if they can replace the axle while they are in there, under warranty. There is a TSB about the axle and they can probably get it all lumped together. That is what I would do (actually, what I did, and I have a new left front axle and cv boot).
Old Jan 2, 2006 | 04:35 PM
turbeaux kid
does it matter that i have lowered the car with springs?????
Old Jan 2, 2006 | 04:46 PM
posthondaremoval
It can. You either want a dealer that is so stupid they don't notice the different springs or one that is so good that they will get it done anyway because they can. I would go for the latter. Hopefully you have a cool dealer in your area.
Old Jan 2, 2006 | 04:48 PM
turbeaux kid
well we will see how it goes.... wish me luck... ill let you know what i find out
Old Jan 2, 2006 | 04:50 PM
posthondaremoval
My fingers are crossed. Too bad you are 1500 miles away I know some good dealers around here, but I am lost in TX. Maybe check in on some local foums to see if anyone knows a cool dealer?
Let us know for sure.
