Wheel hop problem
Old Dec 29, 2005 | 10:40 PM
neon_srt4's Avatar
neon_srt4
Default Wheel hop problem
my car has a real bad wheel hop problem when i launch it and i was wondering if anyone knows what i can do to make it go away
Old Dec 29, 2005 | 10:43 PM
American__Muscle's Avatar
American__Muscle
Default RE: Wheel hop problem
Motor mounts. As with any mod though, there is a compromise, otherwise they would have solved the problem when the produced the car. The compromise is: Stiffer motor mounts for less wheel hop BUT more in-car vibration. If the wheelhop is bothering you that much, then motor mounts are what you need, but be prepared for the vibration.
Old Dec 30, 2005 | 12:07 AM
WhtLightning's Avatar
WhtLightning
Well said muscle. There is another type of device that bolts between the shock tower and the motor mount to stop the engine from twisting. It adds vibration too though.
Old Dec 30, 2005 | 01:21 AM
LilSparkPlug's Avatar
LilSparkPlug
Launch around 1200rpms stock, and feather out the clutch, dont just romp on it. That will solve some of it. Proper launching gets rid of some wheel hop, but with proper launching and motor mounts, your golden. There will/may always be "some" wheel hop, but not such a large amount when things are done right
Old Dec 30, 2005 | 02:24 AM
black srt 4's Avatar
black srt 4
talking about wheel hop I have more then most people. it wheel hop through 1 gear and I launch at 1200 to 1500 rpms. I have energy suspension motor mounts for it I have not put them on yet. I talk to alot of people that have the same problem before they brought these motor mount and they said it work great but you might or still will have some wheel hop to the car.
Old Dec 30, 2005 | 01:58 PM
PSI Chick's Avatar
PSI Chick
inserts aren't going to do a whole lot. they help sure, but a solid mount is really the best option if you want to truly get rid of as much wheel hop as possible.
Old Dec 30, 2005 | 03:45 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: black srt 4
Watch the install on those - use some machine screws instead of the Ziptie fasteners they give you. Your car will thank you when they don't fall out. Prothane makes ones that are 1 piece that are a little more secure, but if you have them already, make sure they stay in there.
Also - what will really help you in eliminating wheelhop much more than inserts is to drop your tire pressure up front. I find that 19 psi at the strip gives a nice hopless launch at 2000 rpm. Obviously, on the street it isn't that smart to take turns at that pressure, but lower pressure will give the tire the ability to sag a little instead of the motor so try dropping it in small increments until it feels better. I would guess that around 25 psi on the street will help a lot. (Just remember not to challenge anyone to a race through the twisties at that level)
