motor mounts supposed to make noises in the engine???
Old Jan 5, 2006 | 10:27 PM
srt4_roller's Avatar
srt4_roller
Default motor mounts supposed to make noises in the engine???
are the agp dog bone motor mounts supposed to make a clunking noise when i give it gas????
Old Jan 5, 2006 | 11:37 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: motor mounts supposed to make noises in the engine???
Not a clunking noise, but the car will vibrate and the powersteering will whine.
Old Jan 5, 2006 | 11:56 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yup. I'd get that "clunking noise" checked out pronto......!!!!
Dusty
Old Jan 6, 2006 | 06:08 PM
posthondaremoval's Avatar
posthondaremoval
Unless it is happening when the compressor cycles on or off, make sure everything is installed correctly - doesn't sound right to me.
Old Jan 6, 2006 | 07:02 PM
svt2srt4's Avatar
svt2srt4
had that problem last week it turned out that the bolt was loose for the upper mount or just not tight enough...check all your bolts to make sure there tight and make sure you use loctite on every bolt except the main bolt that fastens the upper mount to chassis...it has a keeper that holds a nut in place from underneath...i found out the hard way that if you use loctite on that bolt the keeper will give before the bolt loosens then you have a major problem...i had to remove the stock bolt,nut and keeper but now have no problems at all
Old Jan 7, 2006 | 07:59 PM
srt4_roller
i mean i know that they are polyurethane so does that mean when it is cold it could make a noise???? i know that if anything it must be the lower mount because when i put the e brake on and go forward alittle bit it doesnt make that noise. i also know i took my car to the dodge dealer ship to get fixed for another problem and they said they torqued a bolt that connects to the k-frame (what ever that is) because it was loose.
Old Jan 7, 2006 | 09:04 PM
svt2srt4's Avatar
svt2srt4
ORIGINAL: srt4_roller
did you use loctite when you installed te mm's?...and did you back and check to see if all bolts are tight?...also you wont bea ble to figure out where its coming exacly by the nature its acting, what it sounds like seems to be wrong can be way off from the actuall problem ...break out the jack and get under the car and check for yourself...if there is a problem with the lower mm then you could potentially have a bigger problem if not fixed...
Old Jan 7, 2006 | 10:30 PM
Gary Howell's Avatar
Gary Howell
You need to adjust it out and preload the engine. I don't have a picture of the AGP one, but here is the AFX.
If you notice, the threads are made so you can adjust it to be longer or shorter. If you adjust it to be longer it puts pressure on the mount. This will reduce noise and vibration. The noise and vibration mainly comes from the a harmonic that get set up when the mount it exactly the right lenght. This allows it to "float" and causes the problem. Simply lengthen it to get it out of float, and the noise will go away or be deminished.
Old Jan 8, 2006 | 04:33 PM
PSI Chick's Avatar
PSI Chick
dogbones aren't adjustable
Old Jan 8, 2006 | 08:31 PM
Gary Howell
ORIGINAL: PSI Chick
Well that sucks. That means there is no way for him to adjust some of it out without upgrading the motor mount.
