high flow cat
Old Jan 19, 2006 | 04:12 PM
05dodgesrt4's Avatar
05dodgesrt4
Default high flow cat
does the o2 sensor still go in the middle of the cat on an aftermarket highflow cat? can it go behind it on the exhaust side or will that throw a code? thanks
Old Jan 19, 2006 | 05:02 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: high flow cat
ORIGINAL: 05dodgesrt4
Yes. and Yes - you will be cleaner with your downstream after the cat than in the middle. A lot of people leave the ds o2 sensor siptied somewhere under there, s othe ecu thinks the car is running very clean, but I don't know if you would have any issues due to this, I would say your idea is safe, but I am not an expert, and don't do any emissions testing, so maybe someone in anactual garage ought to chime in here.
Old Jan 19, 2006 | 05:10 PM
coyoteyz13's Avatar
coyoteyz13
You have a stage 1 according to you sig. If this is the case, the ds O2 senser is deactivated. You can run without a cat and still not throw a code.
Hey Post, are you coming to the Newark De meet on the 27th? sorry to hijack
Old Jan 19, 2006 | 05:39 PM
05dodgesrt4
thats cool then ill just zip tie it somewhere
Old Jan 19, 2006 | 05:45 PM
highline95jl's Avatar
highline95jl
Id place it in the middle of the cat if I were you.
Old Jan 19, 2006 | 06:14 PM
posthondaremoval
ORIGINAL: coyoteyz13
Good call - didn't notice the s1.
Didn't notice that there was one - I might. Fridays are tough though - what are the details - Pm me.
Sorry 05srt4, back to the topic.
Old Jan 19, 2006 | 07:34 PM
05dodgesrt4
so post you are concurring that the 02 sensor is now inactive and not necessary.
