embelm removal?
Old Feb 20, 2006 | 12:07 AM
orangesrt's Avatar
orangesrt
Default embelm removal?
Does any one know the best way to remove the srt-4 embelm and dealer sticker on the trunk.
Old Feb 20, 2006 | 12:34 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: embelm removal?
ORIGINAL: orangesrt
Do you mean "emblem"? I told my dealer I would not accept a car with a "dealers sticker" on it. Some magic was worked in the prep of the car........no decal. Try asking them to take it off the next time you're there......if they screw up the paint, it's THEIR problem....
Dusty
Old Feb 20, 2006 | 12:48 AM
orangesrt's Avatar
orangesrt
Yea, I meant to say emblem [sm=oopssign.gif]. Guess I will have to actually start checking what I type before I hit enter.
Old Feb 20, 2006 | 01:37 AM
jac05srt4's Avatar
jac05srt4
i just used a heat gun to remove mine. it is easy but you have to make sure you dont let the heat gun get to close to the paint and you have to keep moving so it dont stay in the same spot. but it comes off in no time at all.
Old Feb 20, 2006 | 10:46 AM
SRT_YA's Avatar
SRT_YA
hair dryer... not quite as harsh as a heat gun ;-)
Old Feb 20, 2006 | 04:21 PM
PSI Chick's Avatar
PSI Chick
i just pulled mine off. i took off the dodge but left the srt-4 on. just ripped it right off. goo gone and some denal floss works good too
Old Feb 20, 2006 | 04:36 PM
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: PSI Chick
that is more along the lines of what i was thinking.
I know one of the stickers i pulled off was just a foam backed type application and a little elbow grease and some cleaner took off the rest once i got the emblem off.
Old Feb 20, 2006 | 04:54 PM
roachnigga's Avatar
roachnigga
Dental Floss...once done use goo-b-gone and wash ya car
ORIGINAL: orangesrt
Old Feb 20, 2006 | 05:14 PM
bigddy9's Avatar
bigddy9
Fishing line works a little better than floss (it's a little more durable). Some mineral spirits and elbow grease will remove the rest of the gunk (be very careful with mineral spirits....it will remove the paint if you aren't careful). Make sure you wax the area after you remove everything, all teh stuff you used to take the emblem off will remove wax too.
Danny
Old Feb 21, 2006 | 03:48 AM
71RoadRunner's Avatar
71RoadRunner
My dealer sticker was just a vinyl graphic that peeled right off. I just cleaned up the area and waxed it and theres no trace of where it was. Of course I did it right after I got the car, so it was easy and there wouldn't be any paint fade difference.
