Got some Pics
Old May 22, 2004 | 08:26 PM
  #31
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Got some Pics
Don't forget to hit "OK" or "Apply" at the bottom of the page....[&:]
Old May 22, 2004 | 11:51 PM
  #32
wozman78's Avatar
wozman78
Ok lets see if i did it right and if it even looks good.
Old May 22, 2004 | 11:53 PM
  #33
wozman78's Avatar
wozman78
Guess not i'll keep trying.I suck with computers!
Old May 23, 2004 | 06:47 AM
  #34
71RoadRunner's Avatar
71RoadRunner
I got it on, but not until after the Classics. I'll need to get some mileage on it to see any results, but I know from the factory air box that I will.
Old May 23, 2004 | 04:44 PM
  #35
roachnigga's Avatar
roachnigga
Thnx, RR. Take any info you, Dust, 837... ya have. I havent got mine yet do too work... and duty....
Peace
Old May 24, 2004 | 05:52 AM
  #36
71RoadRunner
I have seen a few different set ups at the classics. One of which capped off the CAI part and had an open element filter on the valve cover part. Another was running both the valve cover,/w CAI capped off, hose and the PCV hose into the same OCC and then into the intake manifold. So apparently my idea is indeed good and sound.[sm=smiley20.gif]
Old May 25, 2004 | 08:23 AM
  #37
roachnigga's Avatar
roachnigga
Having a breather at one end, wouldnt that cause an improper vacuum on the valve? Anyhow, so its cool to "T" off both sides of the valve cover to the OCC. Sounds good to me.
Thnx for Da Tip, RR
Old May 25, 2004 | 08:51 AM
  #38
71RoadRunner
Not a problem. Then you can run it from out of the OCC right into the intake manifold, this is where the PCV hose/line goes to.[sm=smiley2.gif]
Old May 25, 2004 | 08:30 PM
  #39
roachnigga's Avatar
roachnigga
This is gonna look SIcK....
