SRT-4 Body kits?
Old 05-19-2004, 12:34 AM
dustyloins's Avatar
dustyloins
dustyloins is offline
Hall of Fame Member
Location: Alamosa, Colorado (200 yards from the Rio Grande)
Default RE: SRT-4 Body kits?
There are lots of folks (good drivers) running 13.7s -13.9s in their stock 2004 SRT-4s....stage 2 should knock off it down to the mid 13's......or...??????[&:]
  #22
Old 05-19-2004, 12:42 AM
morf's Avatar
morf
morf is offline
i Still havn't got an answer on wiether or not you can put airbag suspension on an srt-4. and if it would increase performance or anything. i would love to get an answer if anyones knows. thanks
  #23
Old 05-19-2004, 01:59 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I'm happy with the suspension on my SRT-4, so I'll leave it to someone else to chime in on this.....[&:]
  #24
Old 05-19-2004, 03:34 AM
morf's Avatar
morf
morf is offline
Well dusty do you think that it will look good? or do you think that having a ST-4 that you can raise and drop with a switch will look kinda tacky? just wondering what you think.
  #25
Old 05-19-2004, 08:16 AM
71RoadRunner's Avatar
71RoadRunner
71RoadRunner is offline
I have only personally witnessed the Stage 1 equipped cars and they were running 13.0-13.2 in the 1/4. Stage 2 should fair alot better, perhaps 12.8-13.0 depending on the driver and track conditions.
FYI: The SRT-4 has a different nose and hood than a regular Neon and I have read that you can not mix and match them(you cannot put and SRT-4's hood on a regular Neon or an SRT-4's nose on a regular Neon and vice versa, you would have to swap both the hood and nose from one to the other). The Evo nose for a regular Neon will not fit on an SRT-4 unless you also put the regular Neon hood on it as well.
  #26
Old 05-19-2004, 12:21 PM
morf's Avatar
morf
morf is offline
well thats good to know. thks. what do you think about airbag suspension?
  #27
Old 05-19-2004, 05:14 PM
badsrt4's Avatar
badsrt4
badsrt4 is offline
whats up man. good to hear u thinking about the srt-4. i tried the best price thing but all i got was $19,000 and some cute k-chains. (2003 srt-4) from what i've heard 2004 its a bit more expensive but good luck anyways man.
  #28
Old 05-20-2004, 12:39 AM
1qwk4's Avatar
1qwk4
1qwk4 is offline
the evo 3 body kit will not fit the srt. the evo 3 is made for 00-02 only. also, the side skirt for the srt is a little shorter than a base neon. here is my car with the evo V body kit. http://members.cardomain.com/1qwk4
ORIGINAL: morf
Has anyone ran a 1/4? and timed it with the Stage 2? 13.5? or lower? just wondering? Oh by the way i found the Evo-3 body kit that says it fits 00'-Up neons so it should fit and you get to keep the fog lamps!@ sweet!
  #29
Old 05-20-2004, 06:37 AM
71RoadRunner
I'm not into the airbag suspension, there is too many things to go wrong and it's expensive to fix. I would just go with an adjustable coil over kit.
  #30
Old 05-20-2004, 06:17 PM
morf's Avatar
morf
morf is offline
So the Evo 5 kit does fit a 04 SRT-4?
Quick Reply: SRT-4 Body kits?
