Found #2 spark plug loose!
Old 02-06-2008 | 07:12 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Found #2 spark plug loose!
last time i changed plugs that were deep in a hole like that, i just used the spark plug socket with an extension. only tricky part is putting the new socket in, getting the socket off the plug and getting it out, as the extension tends to pull off before the socket.
Quick Reply: Found #2 spark plug loose!
