How in the _____?
Old Mar 19, 2006 | 03:46 PM
`71RR383SRT4's Avatar
`71RR383SRT4
Default How in the _____?
OK, how does the radio trim and rear speaker shelf come off with screwing it all up??????[sm=feedback.gif]
Old Mar 19, 2006 | 09:29 PM
jac05srt4's Avatar
jac05srt4
Default RE: How in the _____?
The radio trim piece is easy. You have to take out the two air vents and there are two screws there, take them out. Also take off the air control ***** or when you pull they will go flying. This will enable the whole silver trim peice to come off, then you will see the four screws for the radio. The rear deck comes off pretty simple as well. Start by removing each side panel above the carpeted peice. Then you have to remove the rear seat. Once that is out you will be fine. If you have move questions just email me.
Old Mar 20, 2006 | 12:24 AM
`71RR383SRT4
OK, I'll try this. I hope I don't 'F' it up.
Old Mar 20, 2006 | 01:28 AM
LilSparkPlug's Avatar
LilSparkPlug
Its nearly impossible to screw up. On the vents, pull down and out, don't worry you wont break them.
On the interior C-Pillars, put your fingers at the top, shove them in there, and pull down. Don't be afraid to use force....they wont break unless you're REALLY putting ALOT of pressure on them.
Old Mar 20, 2006 | 01:50 AM
jac05srt4's Avatar
jac05srt4
by the way, you are going to hear popping but it is just pins. even if the pins come off of the panels they easily go back on. good luck. what are you putting in anyway? to be honest, soon i will be working on my audio again, except i will be putting in a double din navi. in. it will take work but it will be nice. also this weekend i just got done dynamating the whole car. what a difference. the fiance was complaining about noise too much. good thing i get everything at cost, that stuff is expensive otherwise.
Old Mar 20, 2006 | 03:57 AM
`71RR383SRT4
Well.............What I am doing is installing the stock 6 disc changer and the Kicker Amp/ Woofer. Some one here was going to send me a pic of her woofer harness location, but I think she forgot about me............(LSP)[sm=bustedsign.gif]..........................................
I know all SRT's have the wiring for the woofer. I just need to find it. I've looked in the trunk. Now I'm looking on the speaker shelf next to the speakers. IT'S GOT TO BE THERE!!!!!!!!!!!!
Old Mar 20, 2006 | 08:28 AM
vaughn's Avatar
vaughn
ORIGINAL: `71RR383SRT4
im sure she didnt mean to forget you........she's practically a star now.so probably stays pretty busy
Old Mar 20, 2006 | 12:03 PM
jac05srt4's Avatar
jac05srt4
If you dont here back from her soon, in the next few days I will stripping my trunk and if I find it I will post you something.
josh
Old Mar 21, 2006 | 04:05 AM
`71RR383SRT4
I've already taken out the trunk liner, and checked the harness that was on the left side and it was just for the tail lights and trunk light. The speaker harness runs up behind the rear seat up to the speaker shelf. Are going take the shelf off??
Ray
Old Mar 21, 2006 | 04:17 AM
LilSparkPlug
DAMN I forgot again. I need to PM you my phone number so you can call me and remind me. The harness sits in the upper left of the trunk, right when you open it look to your left. Theres a little hole type thing in the body. Its where the torx screw goes for the system's harness. Where it runs from there I have no idea. Presumably with the other harness and up to the front of the car. But I haven't actually looked for it.
