stock dyno???
Old May 31, 2004 | 04:37 AM
  #31
71RoadRunner's Avatar
71RoadRunner
Default RE: stock dyno???
I haven't used my A/C yet, so I'm sure my will go down with it as well. As long as I only loose 1 MPG with it on I'll be OK.
Old May 31, 2004 | 03:08 PM
  #32
dustyloins's Avatar
dustyloins
Hall of Fame Member
One thing that did surprise me was the LACK of power loss with the A/C on....except for the cool air blowing out, I forget it's even on....[sm=smiley5.gif]
Old May 31, 2004 | 08:10 PM
  #33
Gump's Avatar
Gump
yeah i liked that fact too... with my eclipse it was easy to tell the preformance loss so i wouldnt use it much...
ORIGINAL: dustyloins
Old May 31, 2004 | 08:15 PM
  #34
dustyloins's Avatar
dustyloins
Hall of Fame Member
I hear ya, in my Mazda B3000 P/U with a V-6, it almost felt like it was going to stall out everytime the a/c compressor kicked in (which it did every 20-30 seconds....)[:@]
Old Jun 1, 2004 | 05:40 AM
  #35
71RoadRunner
My R/T was the same way, with the A/C on you definately knew it was on. There would be off and on lag from the compressor kicking in and a noticable power loss the whole time.
Old Jun 11, 2004 | 11:44 AM
  #36
fortywillys's Avatar
fortywillys
yes 231.6 whp and 248.8 wft-lbs. witch means the big 4 is pushing 250 hp & 275 ft-lbs' at the crank ruffley given a 10 % losse at the clutch
Old Jun 12, 2004 | 06:06 AM
  #37
71RoadRunner
10% seems to be a little on the low side, but since Dodge is so frickin' far off on their ratings of it at the crank, we will only find out if some take them out and dyno them at the crank.
