HOM HELP!!!!
not to steal the thread but on my toys, the IC spray doesnt work. i checked the hoses and water level and its all good. when you use it, are you supposed to see water spraying?
i hope these toys dont have a lot of defects, otherwise mine are just RICE buttons. hehehe.
Well before when i ran the HOM i just had to do a lil push on the button,i never had to hold it down but this thing is irritating me enough that i tried every dab setting i tried to hold the button, pushing the button repeatedly still nothing...One thing i noticed is when i first got everything hooked up the light kind of had a glow to it not like it was on but like it had power to it,but now its just dark!!!!
Ok so i checked the fuses in the wiring harness,there is a blue 15 amp which looked good and there is a 5 amp thats tan.The tan one wasn't busted but the lil coil thing inside the fuse had a really wierd shape to it like it almost got to hot and melted,so i put in another 5 amp in its place and nothing happened!!I looked over all the wiring nothings been pulled out or damaged so im leaning towars it being a bad led,so now my ? is,is there any way to check the system to tell if its a bad light or not?If anyone has any other ideas i am pretty much open to anything right now i need to get this figured out by tomarrow night.
Ok this keeps getting better and better,So im not too sure but i think its a bad led so i thought i would look and see what the price was.Went to the performance catalog on mopar's website and there it is $4.00,so im like sweet ill just buy one and if its not the problem im only out 4 dollars.So i call the local dodge dealer to get a price and availibility and the guy looks it up and WOW my price is $32.00 and it would take a week to get.So im like what the f*ck the website says its only 4 dollars and all he could tell me was,that i was a old catalog and they updated the price.Ok so i need to know what to do to find out if its just a led problem or if its something else?Someone anyone im not picky!!!!!
Ok i got the led out and hooked it up to the battery,it works so i took a test light and started the car pushed the HOM button,touched the prongs on the connector and i have power coming out of it.So the light works and i have power to it,do yo think it might be a ground problem?If it was a problem some where else in the wiring would i still have power coming out of it but not illuminating the light?Thanks for your help i really do appreciate it!!
just go over everything. it might be a ground, it might be a plug that came out of the connector on the ecu, it's very hard to tell. the only way to really figure out what's going on is to get in there and go over everything a few times and make sure that it's all connected. just a slight movement of one wire could be the problem, yes it really could be something that stupid.
