HOM HELP!!!!
Old Apr 6, 2006 | 12:29 AM
flameredsrt's Avatar
flameredsrt
Default HOM HELP!!!!
Okay so i got a big race lined up against some Porsche on N20...I got my New DR yesterday after 2 weeks of waiting,so i figured i would go get a tank of race gas to accomedate(spell check) the tires!!!On my way to the station i pushed the lil red button just out of over enjoyment and nothing happened..So my ? is how do i know if its engaging or not if the red button is not lighting up?If that buttons isn't lighting up i cant tell if i am waisting a $50 tank of gas!!!Sorry but i have a lil money riding on this and would really like to have the assistance of HOM....Any input would be appreciated
Old Apr 6, 2006 | 02:41 AM
moparman04's Avatar
moparman04
Default RE: HOM HELP!!!!
unless the porsche is a 99 or lower boxter your going to get your *** served !!! stage 2 w/ toy's or not... especially if he is squeezing
Old Apr 6, 2006 | 03:27 AM
PSI Chick's Avatar
PSI Chick
the light didn't go on at all? even with no race gas the red light will turn on but then it will blink at you and kick you out of hom and go into limp mode (believe me that sucks, like hitting a wall). if the light isn't turning on at all then there might be a issue with wiring. it could also be a bad led, a few kits have had them. does the led for the ic sprayer work? dab works?
Old Apr 6, 2006 | 03:54 AM
mxrnick's Avatar
mxrnick
i have killed new boxter s turbos in my stock SRT-4. with the stage 2 you will be able to beat most stock porsches. just be careful before you put money down.
Old Apr 6, 2006 | 04:43 AM
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: PSI Chick
If there is a substantial power loss when it kicks out, then couldn't he try simulating that by running it full on and in the middle of a hard run flip the HOM switch off? I would think that should simulate it kicking out of HOM on it's own.
It all comes down to what year and version Porsche, how much spray and/or other mods and how good the driver is. And this also goes the other way too.
Old Apr 6, 2006 | 07:16 AM
posthondaremoval's Avatar
posthondaremoval
Quick easy answer - check the fuse in the toys fuseblock. Sounds like it is blown.
Just a thought,
Also if it is on n2o i am assuming it is a 944. If that is the case you ought to have a shot. but that is mere supposition.
Old Apr 6, 2006 | 10:41 AM
SRT_YA's Avatar
SRT_YA
did the light work before?? or is this the first trial with it??
if it's the first trial, reverse the wires to the LED... some of the kits the wires were put in backwards (I kid you not, it happened to mine, and when I called the tech. support the gentlman said it was an issue)... if it's worked in the past, disregard this post. ha-ha...
Old Apr 6, 2006 | 11:24 AM
PSI Chick's Avatar
PSI Chick
ORIGINAL: 71RoadRunner
just turning off the hom won't really simulate it. when it kicks you out of hom, it goes into limp mode, so it pulls insane timing. it's slower than normal. it's really like hitting a wall. the led would stay on blinking at you until you disengage it.
Old Apr 6, 2006 | 12:49 PM
flameredsrt
Ok thanks for the replies,first thing is yes it has worked before and yes the IC led works and the DAB switch works as well.i checked the wiring and everything looks like its still in tact.I am gonna check the fuse on the harness at lunch today but if anyone else has any suggestions please let me know...
P.S its a 1988 porsche 944 with a 4 cyl non turbo with a 100 shot...The neon nots scared!!!
Old Apr 6, 2006 | 02:37 PM
PSI Chick's Avatar
PSI Chick
stupid question but i have to ask it....as you sure you pushed and held the button long enough for it to engage? just a quick push won't turn it on........
