stage 3
Old Apr 13, 2006 | 10:14 PM
flameredsrt's Avatar
flameredsrt
Default RE: stage 3
Im not to sure but i thought stage 3 w/toys came with a pump and new fuel rail?
Old Apr 13, 2006 | 10:20 PM
envious8's Avatar
envious8
Default RE: stage 3
im at 6500 miles should i still wait to have the stage 3 put it? its already on it way
Old Apr 13, 2006 | 10:23 PM
flameredsrt
Default RE: stage 3
If you can honestly wait to install once you get it your alot stronger person than me..The biggest thing is get use to the car and the speed before you go and bump it up 120 hp.Your fine with mileage just make sure your mentally ready for it cause it ain't no joke!!!Just be careful!
Old Apr 13, 2006 | 10:55 PM
OrangeBlast99's Avatar
OrangeBlast99
Default RE: stage 3
Yea its no joke...
many kids cant handle 250hp, let a lone almost 400...
Old Apr 14, 2006 | 02:54 AM
black4's Avatar
black4
Default RE: stage 3
amen to that ive gotten used to my set up since ive been on it for almost 2 years. one more thing to invest in sway bars and traction bars makes a world of difference in handling and traction.
Old Apr 14, 2006 | 04:15 AM
PSI Chick's Avatar
PSI Chick
Default RE: stage 3
s3 comes with a fuel pump so that's taken care of. most things have been discussed already, so i won't go into them. but some pointers....
1. 3" turbo back is a must. s3 is choked on the borla. maxxfab is awesome i would definetly recommend him, my entire mut of an exhaust is from him!
2. solid mounts need to be installed. no inserts, they're not going to hold up. never heard of these avid mounts so i can't comment on those, but the agp mounts are very nice.
3. look into a lorenzo 60mm throttle body. this wakes up the car unbelieveably! definetly a must if you want the best performance out of the car.
4. maddog shifter is great. i have his 58% redux and i love it. they now come with a rod brake to ensure that you don't over throw and damage trann components.
5. not sure if you've done it already, but new plugs and wires, check valve, and zip tieing the entire car should be in your future. believe me, you will blow lines with s3.
6. i too suggest the ed beast, it's a great fmic.
7. don't bother with the cam gears unless you're getting cams. and definetly ditch the underdrive pulley.
