Code I don't understand
Old Apr 19, 2006 | 06:13 PM
  #21
turbobaby18's Avatar
turbobaby18
Default RE: Code I don't understand
I'm going tomorrow to have the car checked out by this shop. I thought if I cleared the code and it was still a leak the check engine light would come back on.
Old Apr 19, 2006 | 06:30 PM
  #22
LilSparkPlug's Avatar
LilSparkPlug
It will come back on eventually, just give it time.
Old Apr 19, 2006 | 07:00 PM
  #23
turbobaby18
Well I'm getting my catch can put on tomorrow so while they are under the hood I'll just have them check for any leaks.
Old Apr 19, 2006 | 07:12 PM
  #24
LilSparkPlug
Tell them to check the main solenoid, most specifically the one closest to the battery where the black line goes in (two or three down). Thats your factory wastegate line that could potentially be causing the problem. Theres alot of other reasons to throw that code too, but the stock WGA line is the most common.
Remember its not a boost leak, but a Vac leak that would cause this. Good luck and let us know how you make out cause this is bugging me and its not even my car!!
Old Apr 19, 2006 | 07:48 PM
  #25
turbobaby18
Ok I got everything you said and I will have it all checked out. The wastegate on my car looks pretty big and I'm trying to guess if its an adjustable aftermarket one. Does anyone have pics of under the hood of a stock srt-4?
Old Apr 20, 2006 | 02:02 AM
  #26
Pressurecooker's Avatar
Pressurecooker
Lil Spark has done a great job so far but I just want to add the "bad gas cap" could also simply have been a loose gas cap, and, your tranny is due a fluid change at 12,000. The book may give longer intervals, but everyone here will agree the fluid should be changed more frequently. (Much). Use either the Mopar recommended stuff with the extra additive or, use a good synthetic that meets the Chrysler specs. The only one I know of is the Redline C+___?(C+ 4 I think). That is what I'm currently using and I did notice a difference in shift quality immediately. The tranny takes approx 3 qts. I am running straight Redline with no suregrip (posi) additive with good results. Most will tell you to add the additive no matter what fluid you choose. Won't hurt. The Redline will cost approx 9.50 a quart by itself.
Old Apr 20, 2006 | 04:04 AM
  #27
LilSparkPlug
Heres your stage 2 wastegate:
Part numbers:
Adjustable nut:
Old Apr 20, 2006 | 12:44 PM
  #28
turbobaby18
That looks just like the one I have in my car. Is the stock one similiar or completely smaller?
Old Apr 20, 2006 | 12:58 PM
  #29
LilSparkPlug
The stock one is smaller, doesn't have an adjustable nut, and has different part numbers.
So you car isn't stock you may have stage II in the car. Or possibly just the wastegate. Check on the PCM (The computer that sits behind and below the driver's side headlight) and see if it says Stage II Turbo on it.
Old Apr 20, 2006 | 02:12 PM
  #30
turbobaby18
I think it is just the wastegate, When I lookeed at the pcm it looked like the stock one. I'll ask the guy tomorrow when I go to the shop. But if I had stage 2 then I would be boosting more then the 13-14 i am now
