Safe boost?
Old Apr 25, 2006 | 12:03 AM
hawwk11's Avatar
hawwk11
Default Safe boost?
Hey guys -
Im new here and wanted to know how much boost can a srt-4 run safely? I did a search but zilch...
Thanks,
Old Apr 25, 2006 | 12:20 AM
mxrnick's Avatar
mxrnick
Default RE: Safe boost?
i have heard 18 psi on the stock engine. im running like 16-17 with my boost controller. the "check engine" light comes on when i am in too high of a gear and the boost goes to like 20psi.
Old Apr 25, 2006 | 12:41 AM
hawwk11's Avatar
hawwk11
Thanks,
ORIGINAL: mxrnick
Old Apr 25, 2006 | 01:18 AM
black4's Avatar
black4
17 psi on stock fuel system no more.
Old Apr 25, 2006 | 10:24 PM
hawwk11's Avatar
hawwk11
o.k. now with that said if i wer to get say a stage 2 upgrade will i be able to boost more and how much more? What is needed to go over 17 psi?
ORIGINAL: black4
Old May 2, 2006 | 02:46 PM
Valo2170's Avatar
Valo2170
you will need a new fuel pump and stg1 ecu i think.thats what my friend has and he is peaking at 20psi then it drops to 17-18 to red line.Me on the other hand peak at 16-17 maybe 18 on a cool night then it drops to 15 to red line at holds it there.
Old May 2, 2006 | 03:08 PM
LilSparkPlug's Avatar
LilSparkPlug
ORIGINAL: hawwk11
Stage II comes with upgraded injectors and a new PCM to control them, therefore allowing you to run more boost than 17PSI.
What would you need to run over 17psi on a car without any staged kits?
Injectors
SAFC/DTEC etc
WGA
BOV w/hardpipe because over 19/20 the Mopar isnt going to help you
Potentially an upgraded fuel pump
etc etc.....
Old May 6, 2006 | 03:44 AM
TurboPowered's Avatar
TurboPowered
what about the standard 04-05 injectors?
