Fuel filter, location
Old Apr 25, 2006 | 02:28 AM
Four Banger Anger's Avatar
Four Banger Anger
Default Fuel filter, location
Its not in the tank is it???? or is it???? my dealership couldnt give me a straight answer on where it was....they actually said it was in the tank and it never needs to be changed or replaced(YA RIGHT!!!). I want to know because i think thats a route to a starting problem.
Jordan
Old Apr 25, 2006 | 03:44 AM
PSI Chick's Avatar
PSI Chick
Default RE: Fuel filter, location
it's in the tank
Old Apr 25, 2006 | 05:47 AM
Four Banger Anger
how hard is it to replace it? is oviously harder then a normal fuel filter replacement, i really think i need to replace it though.
Jordan
Old Apr 25, 2006 | 02:04 PM
LilSparkPlug's Avatar
LilSparkPlug
You have to drop the entire tank, make sure your as close to empty as possible, and replace it that way. I wouldn't recommend doing it unless you had a lift and something to put the gas in, its not the easiest task.
Just let them do it, trust me.
Old Apr 25, 2006 | 02:42 PM
PSI Chick's Avatar
PSI Chick
it's actually not as hard as you think. you do have to drop the tank, so just make sure that you're as low on gas as you can get. jack the car up and put some stands under her. then unbolt the tank (which is actually only held on by i think four bolts anyway) and drop the tank. the pump, filter, and level are all one assembly. just pop that out the top then swap the filter. replace it back in the tank and bolt here back together. we swaped my whole fuel assembly in like 20 minutes.
why do you think you need to replace the filter anyway?
Old Apr 25, 2006 | 04:55 PM
Four Banger Anger
because i think its dirty and needs a a new one, when i start my car(no matter what the temp) it surges first, it goes up to 200 rpm stops for a second and then revs up to idle. Its annoying me and I asked a few mechanics and they all said its the fuel filter. I just replaced plugs and wires, its just troubleshooting from here...im going to check my injectors and maybe give them a cleaning if needed.
Jordan
Old Apr 25, 2006 | 05:43 PM
Burnout_INC's Avatar
Burnout_INC
surging when you start the car would have nothing to do with the fuel filter.... if it was dirty/clogged your car would either cut out and run like **** or not run at all.
Old Apr 25, 2006 | 06:04 PM
Four Banger Anger
so what would you troubleshoot it to be then?
Old Apr 25, 2006 | 08:10 PM
Burnout_INC
Well I'm not there to hear and look at the car but I would say there isnt even anything to troubleshoot. Every fuel injected vehicle I've owned surges a little bit on startup, hell my explorer with a 302 jumps up a bit over 1.5k rpm if not more on start up, but like I said, I'm not there so its a bit hard to say.
