Cam upgrade??
Old Apr 25, 2006 | 03:35 PM
300ZXSRT4's Avatar
300ZXSRT4
Default Cam upgrade??
I just aquired a set of crane cams and valve springs. I just have an Stage 1 with exhaust and intake. Will upgraded cams be too agressive with an S1?
Old Apr 25, 2006 | 03:39 PM
300ZXSRT4's Avatar
300ZXSRT4
Default RE: Cam upgrade??
By the way the specs are:
Valve lift=9/9mm
Duration=200/200degrees
Lobe separation=110degrees
Old Apr 25, 2006 | 09:53 PM
vaughn's Avatar
vaughn
hi if you look in the drive train performance section you will see some views......personally i think a crane 10/12 or 14 would be ok for the stock motor.....with minor upgrades
https://dodgeforum.com/m_440222/tm.htm
Old Apr 25, 2006 | 11:57 PM
DominicanSRT4's Avatar
DominicanSRT4
I had stage 1 @ 21psi, And 0016 Crane Cams and cam gears tuned. The 0016 are the heaviest cams you can get for street and ive got 50hp gain at 6k rpms and about 60hp peak power. Lets put it like this, without the cams/camgears/valve springs, and fmic, i was 262hp, with all of those upgrades, i was at 327hp with absolutely no tuning what so ever with a 12.1-12.5 a/f. if you get stage 5 cams or the heaviest cams out there then you might be ****ed, my cams, are perfect.
Old Apr 25, 2006 | 11:59 PM
DominicanSRT4
just to add to it, stock block, stock everything, and a cracked turbo which leaked exhaust near the dump. 8 months running, now im with a 57trim. im trying to max out the turbo but the hp keeps up climbing, no sign of it falling at redline. Ill keep you updated when i am done, need more fuel.
Old Apr 26, 2006 | 12:17 AM
Racevette77's Avatar
Racevette77
ORIGINAL: DominicanSRT4
Hay could you pls post what cams / gears you have so that i could look into getting some as well. Thanks
Old Apr 26, 2006 | 12:46 AM
300ZXSRT4's Avatar
300ZXSRT4
ORIGINAL: vaughn
I will look at it, thanks!
Old Apr 26, 2006 | 04:28 AM
PSI Chick's Avatar
PSI Chick
you have a set of crane #10's. good for a stock car, not going to see a huge difference but defiently noticable. if you want the most power you can get, look into adjustable gears, they will allow you to tune the cams.
Old Apr 26, 2006 | 02:08 PM
MChat's Avatar
MChat
Nice. I have the Crane 14's for my new engine... but I am seriously considering going with Crane 18/16 combo (18 intake, 16 exhaust) as I have decided to go with the AEM EMS and will likely to rev out to at least 7k RPM w/ the new GT35R turbo providing the air...
Can I interest anyone in a set of Crane 14's that are brand new, but modified to use the 2.0L cam gears (A much wider selection of Cam Gears available for the 2.0L)
Old Apr 27, 2006 | 12:02 AM
bigham's Avatar
bigham
how much
