Greddy oil can
Old May 4, 2006 | 06:23 PM
Valo2170's Avatar
Valo2170
Default Greddy oil can
Hey guys whats my car is f up i wanted to take my mine off of it and install something.I got the greddy oil can and i dont know how to install it. I just need to know where you stick it at and where the line goes.I know one of the lines go but i dont know where the other goes.Can someone help me or tell me where i should look for install pic. Thanks ERIC Oh and one more thing that little hose that comes with the can the weird line that goes in the middle of the can dos not fit.Its not long.Sorry i cant explain it any better but does anyone know what im talking about?
Old May 4, 2006 | 09:09 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Greddy oil can
If you're talking about that clear plastic tube in the middle, that's an oil level site gauge to tell you how full your OCC is. You can get another piece of tubing probably at Home Depot or Lowe's or just seal off the two metal "spigots" that hold it in place. The Greddy can is pretty big and hard to fit under the hood of an SRT-4. One line needs to go from the PVC valve to your OCC and the other line goes from your OCC to the throttle body. Maybe a pic of my $20 OCC will help....
Don't forget the hose clamps!!!!!
Dusty
[IMG]local://upfiles/894/7753B771FA6C4F9FBA4E6A236BE30F5F.jpg[/IMG]
Old May 5, 2006 | 11:26 AM
Valo2170's Avatar
Valo2170
Thanks man
Old May 5, 2006 | 01:06 PM
Valo2170's Avatar
Valo2170
Hey i have one ? This might be stupid but i am learning LOL. Yours really dont look like it's coming from the throttle body.Is that just the way i install mine?
Old May 5, 2006 | 11:35 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
It's coming from the PCV valve on top of the engine to your OCC, (where the oil will collect) and then to the throttle body. All you're really doing is replacing the line from the PCV valve to the throttle body and inserting the OCC in the middle of the line.....
Dusty
Old May 6, 2006 | 11:43 AM
Valo2170's Avatar
Valo2170
Ok i understand now i had to go out to look at my car to see what your talking about LOL.MY last ? for you is i found a plzce to install it right under the battery tray it fits perfect but the line will not reach to the pcv valve.So i take it i need to go buy a longer line?
Old May 6, 2006 | 11:54 AM
Valo2170's Avatar
Valo2170
Oh and whats the easy way to empty put the occ with out geting oil every where?On my greddy occ that is.
Old May 7, 2006 | 12:10 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Go to any auto parts store and get some Goodyear fuel/emission hose, 3/8", SAE 30R7, it's not expensive at all. As for emptying the can, if you use a mounting bracket to put it on, it's easier to remove........
Dusty
Old May 10, 2006 | 07:55 PM
04srt4lvr's Avatar
04srt4lvr
valo2170 what kind of name is that hahahaahahah just kidding i told you i was a member here too.
