ECU REFLASHED
Old May 27, 2006 | 09:59 PM
street demon's Avatar
street demon
Default ECU REFLASHED
I WANTED TO KNOW WHERE I CAN GO AND GET MY ECU REFLASHED.
Old May 27, 2006 | 10:51 PM
vaughn's Avatar
vaughn
Default RE: ECU REFLASHED
http://www.flightsystems.com/About_Us.htm
Hello,
If you have bought a used stage kit and need your vin number reflashed into it you can send your pcm to me and I can reflash it for you. I can NOT reflash stock pcm's. As you should know, if you do not do this and try to install the pcm in your vehicle without changing the vin, your vehicle will not start. The charge for this will be $30 plus s&h plus the COD charge. I can either ship it back to you overnight air which is expensive or ground which will only cost $4-5 more on top of the $30 plus the $7 charge for COD. The cost for everything will be around $43 which will come COD (collect on delivery). Everything will be sent back using the carrier UPS, no exceptions. When the driver drops your pcm off you must give him a check or money order made out to Flight Systems, for the exact amount. Once I ship your pcm out, I can send you a pm with your tracking number and total COD amount. The address you will need to send it to is:
Flight Systems
1040 East Maple Road
Troy, MI 48083
Attn: Stephanie/Reprogram
Please make sure to put inside the box your vin number, return address, a telephone number I can reach you at in case of any problems, and how you would like it sent back to you; ground or overnight. Please make sure the pcm is packaged properly, any damage that happens on delivery to me is not my respondsibility. Let me know when you are sending it out to me by pm so I know when it should arrive. I will ship it back out to you 1-2 days after I receive the kit. If you have any questions, you can pm me as well. Have a great day!!
Stephanie
Flight Systems
Parts Department
Old May 27, 2006 | 11:39 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Cool. Wonder why they wanted mileage numbers when we bought the Stage 1 NEW.......?
Dusty
Old May 28, 2006 | 02:42 AM
Four Banger Anger's Avatar
Four Banger Anger
stephanie i may be contacting you when i need my ecu reflashed once i get my used stage 1. If the dealer cant or refuses to do it is it because they lack the knowledge to do so?
Jordan
Old May 28, 2006 | 07:59 PM
street demon
THATS COOL AND ALL BUT IM TRYING TO REFLASH MY STOCK ECU. WOULD I JUST HAVE TO GO BACK TO THE DEALER?
Old May 28, 2006 | 08:36 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Save the gas money and just call and ask them......most should be able to do it.
Dusty
Old May 28, 2006 | 09:24 PM
vaughn's Avatar
vaughn
i posted that info for you guys....i dont think stephanie is a member here though
Old May 28, 2006 | 10:08 PM
street demon
DOES ANYONE HAVE AN IDEA ABOUT HOW MUCH IT MITE COST TO REFLASH A STOCK ECU FROM THE DEALER?
Old May 29, 2006 | 02:19 PM
PSI Chick's Avatar
PSI Chick
reflash a stock ecu for what purpose?
but either way, a reflash is a reflash doesn't matter what stage it is. dealers will charge anywhere from $50-100, and some will refuse to do it.
Old May 29, 2006 | 03:31 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
ORIGINAL: PSI Chick
Valencia Dodge wanted to charge me $125 then Glendale Dodge said you can't reflash a stage 1 ecu, they said its *impossible* I am getting it reflashed by a friend of mine, he has that DRB thing and we are going to use it to reflash my ecu.
