Stage 1 Came In Today
Old Jun 13, 2004 | 12:03 PM
71RoadRunner's Avatar
71RoadRunner
Default RE: Stage 1 Came In Today
Hell yeah!!!![sm=smiley4.gif][sm=smiley20.gif][sm=smiley20.gif][sm=smiley32.gif] I knew about the BOV getting better sounding, I've read probably everything ever written on or about the SRT-4's, including all the upgrade installs and comments. They say that the Stage 2 is supose to do that with the BOV even more as well as the Mopar Borla exhaust too. I was shocked to see that they put the PCM right next to the radiator, no wonder the other side is a big heat sink.[sm=smiley5.gif] Can't wait to hear about it after you get it on.[sm=smiley20.gif]
Old Jun 13, 2004 | 04:13 PM
jackhole 101's Avatar
jackhole 101
if you are worried about heat getting to the curcuit board from running the extra power and octane...try this. Get yourself some "dynamat" engine compartment heat reducing layering. That way, you can shroud your inportant materials with this stuff and not worry about the aluminum computer boxes gathering tooo much heat on your way up to 250 horses.
Old Jun 13, 2004 | 06:16 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I'll check it out, thanks for the info!!![sm=smiley20.gif]
Old Jun 13, 2004 | 08:41 PM
Wheat_Burner's Avatar
Wheat_Burner
"I've read probably everything ever written on or about the SRT-4's, including all the upgrade installs and comments."
71RR - Have you read some of the posts on other boards regarding dyno's that were run on Stage 2 SRT-4's? Some have claimed to have actually lost, or had minimal WHP gains after install. I don't see how this could be true, but it is something that has me concerned. I had planned on Stage 2 with toys, but I'm waiting until I can get more info from some people that have it.
Old Jun 14, 2004 | 12:36 AM
jackhole 101
you install that badboy yet?
Old Jun 14, 2004 | 12:48 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
My days off are tomorrow and Tuesday....Got my tools out in the garage, a stocked ice chest and my boom box loaded with my favorite tunes.....gonna get up early so I can get it done before the heat/humidity becomes a issue....
Old Jun 14, 2004 | 12:52 AM
jackhole 101
it shoudl only take you about 30 minutes or so...just make sure that you get all the o-ring out before you throw the new injectors in it...and also...when you try to re-fire it, prime it a few times by going from off to "on" in the ignition about 3 times to get everything preasurized...then crank it and it should fire right up.
Old Jun 14, 2004 | 11:16 AM
71RoadRunner
That only applies for the '03 SRT-4's. The '04 SRT-4's already have the larger Stage 1 injectors in them from the factory, so all he has is the PCM.
I haven't heard of any power losses from Stage 2 yet. It sounds to me like they either did it incorrectly or received PCM's that were never flashed with the Stage 2 programming.
Old Jun 14, 2004 | 07:25 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
RR, check out the thread "new to the SRT4 street scene" and the postings by PSI Chick...she confirmed what I read on another forum about leaks with the Stage 2 and making a leak detector.....[sm=smiley5.gif]
Old Jun 14, 2004 | 11:32 PM
seanie719's Avatar
seanie719
Hey dusty..how much was the stage 1 havin 04? Is it cheaper since you don't need the injectors?
