Stage 1 Came In Today
Old Jun 14, 2004 | 11:40 PM
  #21
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Stage 1 Came In Today
I got it from Modern Performance for around $330 plus shipping and tax (if you live in Texas)...yes, it's cheaper than the $399 listed on the Mopar web site for the Stage 1. Give the guys at www.mondernperformance.com a call....they know their stuff.[sm=smiley16.gif]
Old Jun 16, 2004 | 08:00 AM
  #22
71RoadRunner's Avatar
71RoadRunner
I'll second that, all my SRT-4 mods were bought through Modern Performance, except my 2 OCC and my Mopar Performance BOV.
Old Jun 16, 2004 | 07:20 PM
  #23
dustyloins's Avatar
dustyloins
Hall of Fame Member
I have to admit I like the fact I get my stuff extra fast since I'm only 200 miles away.... [sm=smiley36.gif]
Old Jun 17, 2004 | 06:44 AM
  #24
71RoadRunner
I'm more like 2,000 miles away and I get my stuff in around 3-4 days.
Old Jun 17, 2004 | 08:03 PM
  #25
dustyloins's Avatar
dustyloins
Hall of Fame Member
UPS must have some SRT-4s hidden somewhere!!![sm=smiley36.gif]
Old Jun 18, 2004 | 08:58 AM
  #26
71RoadRunner
Yeah, but I don't think the exhaust box would have been able to fit in one though.[sm=smiley36.gif]
Old Jun 29, 2004 | 08:21 AM
  #27
srt4driver's Avatar
srt4driver
so when it comes down to it...whats better, stg 1 or stg 2?
Old Jun 29, 2004 | 08:46 AM
  #28
71RoadRunner
Here is how it breaks down for all 3 Stages of turbo upgrades. And naturally the Stage 2 is far better than the Stage 1, especially when you get Stage 2 with the turbo toys.
NEW! TURBO UPGRADE KITS
The Dodge SRT-4's are already hot numbers,
but Mopar knows that more is better, so the Stage 1, 2 and 3 Turbo
Upgrade Kits are on the move to give them just that! Proof that
Mopar Performance engineers want the same thing you do — more
power ... NOW!
STAGE 1 TURBO UPGRADE KITS — SRT-4
The Stage 1 Turbo Kit for the SRT-4 boosts power to 240 hp and
260 ft-lbs. of torque.
Components
• Stage 1 PCM
• (4) 577 cc/min fuel injectors
(2003 kit only)
Calibration Features
• Increased WOT and part throttle boost
• Improved turbo response
• Boost hold feature during WOT shifts
• Enhanced 1st gear boost schedule for a high-performance launch
• More aggressive exhaust note during deceleration
• Optimized calibration for the Mopar Performance Blow-Off Valve
Conversion Kit (P4510548)
*P5007862 2003 SRT-4 Stage 1 Turbo Upgrade Kit
*P4510592 2004 SRT-4 Stage 1 Turbo Upgrade Kit
STAGE 2 TURBO UPGRADE KITS — SRT-4
The Stage 2 Turbo Kits for the SRT-4 give you a power
boost of 265 hp and 280 ft-lbs. of torque on premium pump gas.
You can also achieve 280 hp and 300 ft-lbs. of torque on
100+ octane unleaded racing fuel. For additional power and a more
aggressive exhaust note, you can add our new Cat-Back Exhaust
Systems
• Stage 2 PCM
• Turbo toys (SRT-4 only)
— Turbo Intercooler Sprayer
— High Octane Fuel Switch
— Dial-A-Boost “Down†Switch
— All necessary wiring, switches and mounting hardware
• (4) 682 cc/min fuel injectors
• Wastegate actuator
• 3.0 Bar MAP sensor
• 3.0 Bar TIP sensor
*P5007863 2003–04 SRT-4 Stage 2 Turbo Upgrade Kit
STAGE 3 TURBO UPGRADE KITS — SRT-4**
For maximum power and torque — target is 300hp/300 ft-lb. of torque
— the Stage 3 Turbo Kit is the ultimate upgrade for your SRT-4.
Includes all Stage 2 components plus the following upgrades:
• Stage 3 PCM
• TD05HR-15GK2-10cm2 turbo unit
— 16% larger compressor wheel diameter to flow and compress
more intake air
— 19% larger turbine wheel diameter to flow more exhaust gas
and reduce back pressure
— 67% more turbine scroll area for reduced back pressure
• High-flow (75 psi) fuel pump module
• Demand-regulated fuel rail assembly
*P5007864 2003–04 SRT-4 Stage 3 Turbo Upgrade Kit
*P4510256 2003–04 SRT-4 Stage 3 Add-on Kit
(for vehicles with Stage 2)
Old Jun 30, 2004 | 02:50 PM
  #29
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default First Mod...What do you think???
ORIGINAL: 71RoadRunner
power ... NOW!
Components
• Stage 1 PCM
(2003 kit only)
Systems
• Stage 2 PCM
• Stage 3 PCM
more intake air
Thanks for info, RR!!!!
Old Jun 30, 2004 | 09:06 PM
  #30
glhs837's Avatar
glhs837
Nope, sure won't, but that's okay, I ordered mine through my dealer, when I picked it up, I just told them to keep the box
