Oil catch can help?
Old Jun 6, 2006 | 12:33 AM
motorboy1's Avatar
motorboy1
Default Oil catch can help?
Ok heres the deal i just got an 05 srt-4 on my birthday. I bought it used with 4000 miles on it. Its got a few thing done to it like the wastgate and boost controler but not an OCC so after reading how importand it is to have one i bought a weapon-r. I know, I know, I could have done it alot cheaper, anyway i hooked it up today PCV>>>CC>>>Intake and I end up with a funny idle (high mostly and jumpy) did I do something wrong? help me out please!!!
Old Jun 6, 2006 | 12:43 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Oil catch can help?
The hose you used might have collapsed from the heat.....what type did you use?
Dusty
Old Jun 6, 2006 | 04:28 PM
Plan B's Avatar
Plan B
ORIGINAL: motorboy1
Well, if you truly hooked it up like you said you did, then that is your problem! It should be PCV>>>CC>>>TB & Whatever-you-call-the thing-on-the-otherside-of-the-valve-cover>>>>CC>>>Intake. These are two different setups and it seems you combined them.....
Old Jun 6, 2006 | 07:06 PM
motorboy1's Avatar
motorboy1
Yea your right I hooked it up PCV>>>CC>>>TB like you say. I was mistaken in the way i wrote it. Guess i need to give the right information if i want answers. duh!
Old Jun 6, 2006 | 07:13 PM
motorboy1's Avatar
motorboy1
I used the line they gave me its clear with a white braided look to it. Your right it does collapse from the heat! so thats my problem then? What about the fact that my OCC has a built in filter thats open to the atmosphere? Isn't that a big vacume leak at the TB wouldn't that cause my idle problem??? hmmm
Old Jun 7, 2006 | 12:59 AM
`71RR383SRT4's Avatar
`71RR383SRT4
The filter should NOT be open. The only time it should be open is to dump out the oil thats in it. Yes, you have a MAJOR vacuum LEAK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Old Jun 7, 2006 | 01:09 AM
vaughn's Avatar
vaughn
yea you got the wrong catch can........that catch can is for use if you have a after market air intake.... you need one that doesnt have a vent hole
Old Jun 7, 2006 | 10:35 AM
71RoadRunner's Avatar
71RoadRunner
An OCC should be a sealed unit that catches the oil in a removeable or drainable container. An open element air filter is nothing more than an open element air filter and not to be used on/in the PCV line. A common mod is to use an open element air filter on the emissions hose or the valve cover itself on the drivers side of the valve cover that goes to the air box or the intake tube on a CAI and a cap on the other end (the cap being on the CAI tube or air box where that hose originally hooked up to). Just get the Campbell Hausfeld MP5138 from Auto Zone and follow the instructions in the thread above about the $20 OCC installation instructions. Here is a link to it: http://www.campbellhausfeld.net/weba...9493&langId=-1
Old Jun 7, 2006 | 05:43 PM
motorboy1's Avatar
motorboy1
Ok thanks guys. That sux oh well now I know ill fix it up the right way!
Old Jun 11, 2006 | 09:58 PM
motorboy1's Avatar
motorboy1
Well I went to pep boys last week and got heater hose and a plug to plug the vent. It worked awsome for a week no problems at all! then today I guess it had to much boost and blew the weld apart at the top of the can. It sux and funny at the same time I love BOOST and HP does wonders on parts!!!!
