Radio Help?????????
Wow are you serious? Because all that ebrake does is pop a ground, theres one wire going to it.....so if you cut that wire engaging the ebrake wouldnt have anything to do with it? Or I could be wrong.
apparently they caught on to.how easy it was to bypass.....so they came up with this new way......
heres a post from a owner I have a JENSEN VM9311 and i want to bypass the parking brake safety, I have read about just grounding the wire but i do not think that will work with this model because in the manual it says I need a sequence, Engage the barking brake, release the parking brake for 1 second then reapply the parking brake. I need a way to bypass this please...........
