extra bolts in stage 3 kit ?????Help ASAP
Old Jun 22, 2006 | 08:39 PM
BlackZSlayer's Avatar
BlackZSlayer
Default extra bolts in stage 3 kit ?????Help ASAP
I just got my stage 3 kit in and am putting everything together but dont know what the little bolt and the black washer go to that was in with the manifold bolts. Dont know about everyone else but the only instructions I have is on the dvd and it sucks buttt. Any help will be greatly appreciated.
Old Jun 23, 2006 | 04:11 AM
PSI Chick's Avatar
PSI Chick
Default RE: extra bolts in stage 3 kit ?????Help ASAP
it's a spacer for the top heatshield, the wga arm will hit it if you don't put it in. just put a little rtv on the spacer to keep it attached to the heat shield and install it. it's in the directions somewhere.
Old Jun 24, 2006 | 12:46 AM
BlackZSlayer
thanks alot and I didnt get any instructions with my kit. Dont know why????? But I finally got it in and just wanted to ask you if theres anything you would suggest and how much power does stage 3 with toys put down on the dyno. I have cai, maxxfab catless dp, modified borla, plugs wires. Thanks again.
Old Jun 24, 2006 | 12:37 PM
Nicky B's Avatar
Nicky B
ORIGINAL: BlackZSlayer
With the high octane mode on you will see over 350HP, 400HP should be possible wiht more bolt-on's. What I don't like about the stage 3 is for 4k you only get around 400HP at the most while a 50trim turbo kit will get you over 450HP. But the stage 3 doesn't require much tuning so thats why I like it.
Old Jun 25, 2006 | 08:56 PM
BlackZSlayer
Thats why I got the stage 3 so that all I had to do is put it on and go plus the reliability. Also my goal was 400 horsepower just enough to beable to outrun 95% of the cars where I live.
Old Jun 25, 2006 | 09:16 PM
Nicky B's Avatar
Nicky B
Better get some very tires with traction bars or something or you will be spining through 1st and 2nd gear. Have you thought of maybe just alittle 50shot of nitrous. A 400HP srt-4 is good for high 11's.
Old Jun 25, 2006 | 11:04 PM
rare04's Avatar
rare04
do you have any pics of the stg3 on the car?
Old Jun 26, 2006 | 12:13 AM
BlackZSlayer
I can take some pictures but if you want to know what it looks like just go look at a stock srt 4 because unless you notice the blue hose from the fuel rail or the extra wires for the toys you really cant tell the difference.
Also what kind of bolt on would I need for 400 horse power.
I have 235's on my car so Ill try them if I cant hook up at all ill look into the traction bars.
Thanks again for the help.
Old Jun 26, 2006 | 01:26 AM
rare04's Avatar
rare04
FMIC if your still running the stock, intke 3" recomended, I'm assuming you have the fuel system already upgraded. and full exhaust I have a turbo back 3" injen Its awesome. Thats a few that I would recomend. oh yeah don't forget the "sticker adds horsepower upgrade" load your ride up so it looks like a 4 wheel billboard and that will get you to 400+ hp. LOL!!!!!!!!! later
Old Jun 26, 2006 | 03:29 AM
PSI Chick's Avatar
PSI Chick
s3 will net you different results depending on what your mods are. i did 355 on pump gas at 20psi two weeks ago, but i have a lot of supporting mods (list is on my cardomain page in my sig).
