Considering STS and Bushings
Old Jun 28, 2006 | 01:03 AM
manninej's Avatar
manninej
Default Considering STS and Bushings
I've been considering purchasing a STS and shifter bushings for my SRT, but I need some input and opinions on what I'm thinking. Right now I'm looking at the Mopar STS and Energy Suspension shifter bushings. What are your thoughts on this combination? I would appreciate your comments as soon as possible since I have the extra cash now and may not tomorrow. Yeah, I know it's not a lot of money, but it's the best I can do right now. Thanks.
Old Jun 28, 2006 | 01:06 AM
manninej's Avatar
manninej
Default RE: Considering STS and Bushings
Also, will I need, or should I get, a new ****? And, how do I get the stock **** off?
Old Jun 28, 2006 | 01:20 AM
05ocsrt4's Avatar
05ocsrt4
stock **** jus pops off, with car off put the car in 2nd and try to pull up on the ****, most ppl have the stock **** fly off while shifting into 2nd too hard
Old Jun 28, 2006 | 02:56 AM
04_T_4's Avatar
04_T_4
I think that I am going to get the sts from glacialgraphics.net It seems to be pretty good for the money. Also, I am going to get some booger bushings.
Old Jun 28, 2006 | 03:06 AM
LowSlowNeon's Avatar
LowSlowNeon
Good decision. The booger bushings kick ***. I like the shifter as well. Woot.
Old Jun 28, 2006 | 03:16 AM
04_T_4's Avatar
04_T_4
Any thoughts on the best place to get the booger bushings?
Old Jun 28, 2006 | 05:22 AM
71RoadRunner's Avatar
71RoadRunner
It is a fantastic mod that you'll always love. The Mopar Performance STS replaces the whole shifter keeping everything right and shortens the throw quite a bit and it's easy to change (about 10-15 minutes), but the bushings on the transmission linkage will take a while since it's kinda hard to get to.
Old Jun 28, 2006 | 06:10 PM
yorksrt's Avatar
yorksrt
you can get the booger bushings at turboneonstore.com for $22 or at turbowholesale.com for $21. you might could find them cheaper somewhere else, just depends on who you like. i've got the perrin STS and love it because you can adjust the height up or down by an inch or two. mine is set as low as it will go and haven't had any problem yet, except for getting to it. pulling that center console out is a pain, plus you might have to readjust your e-brake after you get done. there may be a simpler way, but i don't know.
Old Jun 28, 2006 | 06:20 PM
flameredsrt's Avatar
flameredsrt
I have the Mopar STS without the booger bushings.I am very satisfied with it,shortens up the throw quit a bit.I steered away from the bushings cause it seemed like more hassle than it was worth.
Old Jun 28, 2006 | 06:47 PM
yorksrt's Avatar
yorksrt
the bushings aren't that bad to put in. take out the battery, tray, and intake and it's all right there. maybe 15 mins. under the hood. lots of grease helps them go in. they come with pretty descriptive instructions so it's almost impossible to mess up. don't remember if it really helped since they were one of the first things i did 2 years ago. they haven't messed up so i guess they're alright.
