how to adjust bump stops ?
Old Aug 22, 2006 | 05:27 PM
kpsrt4's Avatar
kpsrt4
Default how to adjust bump stops ?
how do you adjust bump stops when installing lowering srings ?
Old Aug 23, 2006 | 06:30 PM
ericorange05's Avatar
ericorange05
Default RE: how to adjust bump stops ?
Have you started the drop yet? Once you take the coil over out of the car and take the springs out, the bump stop will slide off of the shock the same way the spring came off. You wont see it untill you take the boot that sets under the spring. Slide them off and cut/trim them with a saw or razor blade knife.
Old Aug 24, 2006 | 01:27 AM
kpsrt4's Avatar
kpsrt4
have not started yet but plan on doing it tommorw. i will be installing eibach pro kit springs and tokico illumina adjust 5 shocks and rear end links. just wandering if there was a certin amount to cut off or how long it should be ? also just installed aem cold air intake should i get a occ and if so whats a good one to go for ? thanks alot ![sm=massbounce.gif]
Old Aug 24, 2006 | 03:46 AM
04_T_4's Avatar
04_T_4
Yes, you should get an OCC. I made mine. You will get alot of people tell you different things like, make one its cheaper, or buy one then you dont lose boost. Like I said, I made mine and dont lose any boost. There is a sticky on this subject at the top of the main page.
Old Aug 24, 2006 | 11:29 PM
Plan B's Avatar
Plan B
ORIGINAL: kpsrt4
If you are reffering to the line that goes into the intake, just cap it off on the intake and put a breather on the line that comes out from the valve cover..... You don't really need an occ there, but you do need one between the PCV valve and the throttle body....
