stage 2 wastegate on stock pcm...
Old Sep 7, 2006 | 06:55 PM
moparman04's Avatar
moparman04
Default stage 2 wastegate on stock pcm...
anyone ever had any problems ???
so far so good with me, just wanted to know if there are any problems comming in the future
Old Sep 12, 2006 | 04:49 PM
Pressurecooker's Avatar
Pressurecooker
Default RE: stage 2 wastegate on stock pcm...
I guess not!
Old Sep 12, 2006 | 10:55 PM
moparman04's Avatar
moparman04
lol i guess not is right...
i do have to reset my pcm every 2 or 3 weeks though
other wise overboost code pops up... so is this bad ?
Old Sep 12, 2006 | 11:07 PM
rare04's Avatar
rare04
to avoid the overboost codes, you need to disconnect the red line going to the upper hard pipe and cap the fitting on the hard pipe with a rubber cap. The pcm wont know how much boost your boosting. I have had mine like that since day one of the mods and no problems.
Old Sep 13, 2006 | 01:51 AM
808srt's Avatar
808srt
ok i got a question if the cil keeps coming up because of over boost is that bad for the car and this red line that you are talking about do you disconnect the red line from both ends and cap it at both ends or what do you do and i am sorry for the stupid question and one more not to smart queston where do you reset your pcm? thanks
Old Sep 13, 2006 | 06:04 AM
moparman04's Avatar
moparman04
there is a fuse you can pull out to do it, but i dont know witch one
i just unplug the battery
Old Sep 13, 2006 | 11:40 AM
Burnnout's Avatar
Burnnout
808 ... you just have to cap the line at the hardpipe... if you capped both ends you would not have the line connected to the car at all ...lol
Old Sep 13, 2006 | 02:26 PM
808srt's Avatar
808srt
thanks for the info so you unplug from the hard pipe and just let it hang there and then plug the hardpipe right but then again thanks for the info
