Alignment
Old Sep 14, 2006 | 02:46 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: Alignment
There is one adjustable angle on the SRT-4 when its in its stock form. Thats one of the casters I believe. Not sure whether its front or rear.
I put my car up on the rack. There are mopar camber bolt kits, and other kits used to adjust the toe that you have to buy from the dealer if you want to adjust the aligment of the car. Just an FYI, if you ever take your car in for an alignment, and all the boxes are green, they reset the machine, because in stock form, as I said nothing is adjustable.
Old Sep 14, 2006 | 07:47 AM
Pressurecooker's Avatar
Pressurecooker
I haven't even driven the car since I typed that. I drive my beater truck to work and the wife uses the car. We work opposite shifts so I don't really get near the car Mon to Fri, though I will say since rotating my tires front to rear which I did 2 weeks ago, it seemed to pull less but I did not drive it much to really know. I'm hoping to get time to play with it this weekend.
