Question to all owners
Old Sep 14, 2006 | 01:05 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: Question to all owners
driving in the snow with R compund tires sucks. it will go downhill quite well, and thats about it. winter tires are a must, but we avoided driving it in the snow at all costs.
Old Sep 14, 2006 | 02:48 AM
LilSparkPlug's Avatar
LilSparkPlug
I have 15" steelies, and all season tires. Starting off in second when its really bad, and having a boost controller to turn it way down, help immensely.
I live in the great northeast. We get as much snowfall as you guys do, and my car has seen two winters, and he's still running strong, trucks through it like its nothing.
Old Sep 14, 2006 | 07:51 AM
Osmosis_joet's Avatar
Osmosis_joet
awesome thanks i just dont wanna get something that wouldnt be able to handle the weather down here. that would be pointless....eh
Old Sep 14, 2006 | 01:36 PM
PSI Chick's Avatar
PSI Chick
all season tires aren't going to cut it in the snow, a dedicated set of snow tires is really your best bet if this is your daily driver. i solved the problem by getting a TJ
burnnout - staged ecu's do the same thing as long as they are controlling boost.
Old Sep 15, 2006 | 06:47 AM
71RoadRunner's Avatar
71RoadRunner
SRT-4 w/stock tires + snow = russian roulette! Snow tires are a must for winter unless you like complete uncontrollability akin to trying to rollerblade on oil covered ice.
Old Sep 15, 2006 | 08:48 AM
talisman's Avatar
talisman
LOL, I guess it all depends on who you ask Osmosis. The people in the colder snowier climates say you gotta have snow tires. Here in Virginia I got around on Stock tires though I didn't particularly feel good about it. You don't see Snow tires here in Virginia except on pickup trucks and nobody in Virginia has needed snow tires since the Blizzards of 1996.
Then you needed snow tires, chains and probably a dump truck with a plow and spreader.
Good luck with your choice.
Old Sep 15, 2006 | 03:38 PM
flamingpinhead
Section Moderator
^if there is ANY kind of snow on the ground youll be in serious trouble with stock tires!
btw, LILSPARK, you had no problem with the 15" rims? what size did you run on the 15s???
