eyelid install !
Old Sep 18, 2006 | 07:36 AM
moparman04's Avatar
moparman04
Default eyelid install !
how hard are these things to install CLEANLY ??? ive heard a few horror stories ( pops )
Old Sep 18, 2006 | 09:01 AM
carcrazy's Avatar
carcrazy
Default RE: eyelid install !
A pain in you know what . I purchased some of these never was able to get all the bubbles out and have it look worth a dam,
thinking about sticking with the carbon fiber ones a little more money but less hassle
Old Sep 18, 2006 | 07:12 PM
SRT_YA's Avatar
SRT_YA
the fiber glass (or carbon fiber) ones are easy to install... I'd suggest spending the extra cash... but that's just me...
Old Sep 18, 2006 | 07:27 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Vinyl ones......[sm=smiley21.gif] Carbon fiber/fiberglass/plastic......[sm=smiley20.gif]
Dusty
Old Sep 18, 2006 | 08:55 PM
Plan B's Avatar
Plan B
I just ordered the fiberglass set from CBD for this exact reason.....
Old Sep 18, 2006 | 10:45 PM
srt4babe's Avatar
srt4babe
I have the vinyl ones on right now, but I personally think they look like crap.
if you do go with the vinyl ones and pull all your hair out. . . take the housing completely out to do it and wrap the top of the vinyl down or it will split and bubble.
Old Sep 19, 2006 | 01:19 AM
winniep's Avatar
winniep
I would NEVER suggest using vinal, but if you do use a little water with a touch of soap mixture in a spray bottle, then use a plastic squeegee to get the bubbles out.
Old Sep 19, 2006 | 02:38 AM
moparman04's Avatar
moparman04
so i basically wasted 20 bucks ?? [:@]
Old Sep 19, 2006 | 03:24 AM
`71RR383SRT4's Avatar
`71RR383SRT4
Travis, try putting them on. If you don't like them take them off. I like mine, even with the bubbles.
Pops
Do you still have the clear brake light lens?? Bring it to the meet
Old Sep 19, 2006 | 04:30 AM
Pressurecooker's Avatar
Pressurecooker
I have the vinyls. They look great. Everyone who sees them likes them. I got mine from ruthless graphics. They came with instructions, but if yours didn't, you can go to their website and print the instuctions from there. It helps if you have installed anything vinyl before, and I had my wife help as it seems to be a bit much for 2 hands. Use soapy water, but by that I mean like a tablespoon of dish soap in half a bucket of water.
Couple of tips are; (1)The vinyl will be much easier to install if it is warm. Do it in the sun or a heated garage or have a warm heat lamp or halogen
work light nearby to keep the surface and the vinyl warm, not hot, while you work.
(2)The light lens is plastic and will scratch so do not use an abasive to clean it or cut the vinyl against it.
(3)With the soapy water, you can work the vinyl around for a little bit before it sticks too much. Use a soft plastic spatula or bondo
spreader to work the bubbles out. You will not get 100% of them out. No worries, just poke the bubble when you have it
worked up tight with the corner of a razor blade or tip of an exacto knife and squeeze the water out. The bubble will/should
disappear and the tiny hole you made will be invisible and will not cause problems.
It's a great mod. One of the best for the money.
Heres mine;
[IMG]local://upfiles/15665/6D1901116C294CC487085BAD1FDCCF3A.jpg[/IMG]
