Spark Gap?
Old Jul 11, 2004 | 04:56 AM
t0973mf's Avatar
t0973mf
Default Spark Gap?
Why is the gap being reduced when more mod's are added? I always thought you increased the gap for more power. What's the going gap these day's?
Old Jul 11, 2004 | 12:08 PM
71RoadRunner's Avatar
71RoadRunner
Default RE: Spark Gap?
They probably close the gap to keep the spark. Turbocharged engines, especially modded ones, can have a spark blow out problem at full boost. That large amount of air being forced in is actually blowing the spark plugs spark out.[sm=smiley2.gif]
Old Jul 11, 2004 | 10:44 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
The factory setting is .050......some of the guys at the other sites say they are running gaps as small as .035....[&:]
Old Jul 12, 2004 | 07:55 AM
roachnigga's Avatar
roachnigga
I read about the .035 gap. But, is it safe![&:] .050 seems a little big for a gap size. i know of alot of deisel (Turbo) with gap sizes(+) this high. I was shooting for .038 -.040. Any remarks on that.
Also, should i go for the NGK spark plug (Platinum) or should i just reduce the stock ones...
On a different note! The 3" O2 housing install is a REAL Freakin PAIN[:@][:@]. For guys who doin the same... take to the shop... just an advice
Old Jul 12, 2004 | 11:13 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Roach, what are you running on your plugs?[&:]
Old Jul 13, 2004 | 04:01 PM
roachnigga's Avatar
roachnigga
whatever the stock car is...[&:]
Old Jul 14, 2004 | 09:20 PM
PSI Chick's Avatar
PSI Chick
since you have stage 2, i would suggest the champions at .035 or the ngk's at .040. that's what we run on all the strage 2 cars around here, and it's worked very well for us.
on a stock car .045 seems to be the best gap, but it's very dependant on the car. trial and error seems to be the best way to go on that one.
Old Jul 14, 2004 | 09:29 PM
roachnigga's Avatar
roachnigga
Thanks PSI. I am leaning on changing out the plugs, but which one has a "colder core" the NGK or the Champion? Also, is there a website i can use to get'em
Peace
Old Jul 14, 2004 | 09:37 PM
PSI Chick's Avatar
PSI Chick
the ngk's are one range colder than the champions. you can get the ngk's at sparkplugs.com, or your local napa should have them. ngk plug number LZTR5A-13, stock number 4306. the champions you should be able to get just about anywhere.
Old Jul 14, 2004 | 09:41 PM
roachnigga's Avatar
roachnigga
Its a little difficult cuz im in Germany right now[&:]. and the nearest NAPA is across the Atlantic. But thanks for the site.. Ill hit it up today for the NGk's
Peace
