mopar bov conversion kit... worth it?
Old May 22, 2008 | 10:31 PM
  #31
mike_Rocha's Avatar
mike_Rocha
Default RE: mopar bov conversion kit... worth it?
would my bov (mopar)work best if i get a new wastegate for my srt-4 ?
Old May 24, 2008 | 08:01 PM
  #32
flamingpinhead's Avatar
flamingpinhead
Section Moderator
its really easy to install. the instructions that came with it sum it up. the only b**** is getting to the furthest bolt. easiest way would probably be to just remove the intake to access back where the surge valve is. all you gotta do is remove the three bolts holding it in, place the blue plate and gasket in properly (most important). and bolt it all back up. im sure there is a how to somewhere out there.
http://www.srtforums.com/forums/f75/...-install-8819/
i know the link on the 1st page dosent work but im sure if you sort through all 15 pages there is a good how to or link there somewhere.
