Stage 1
Old Oct 28, 2006 | 12:54 PM
GPtuner's Avatar
GPtuner
Default RE: Stage 1
ORIGINAL: tunerbooner
dude get a drift one for corners and and a new muffler pipe ur ride would sound wicked!?
WTF x1000???
tunerboomer your either under the age of 15, and have become addicted to the initial-d anime and saw tokyo drift one too many times, and/or just a complete ricer..... drift one for corners???? and new muffler pipe??? who the hell is this guy???!!! seriously it's hard to ignore stupidity of this kind and NOT add my two cents
Old Oct 28, 2006 | 12:59 PM
GPtuner's Avatar
GPtuner
Default RE: Stage 1
lmao someones messing around ^^^^^^^ dunno who it is but all of there posts have been cracking me up
Old Oct 28, 2006 | 01:13 PM
manninej's Avatar
manninej
Default RE: Stage 1
How do I go about making sure that I have the right A/F ratio?
ORIGINAL: slysliknwiked
it will still be cheaper to buy a used stage 1 kit and getting it reflashed than buying it new just like dusty said as long as its for your year car, now boosting up to 17 psi is not dangerous for your car, you just have to have the right a/f ratio and your good, i have about 10 of my friends boosting at about 20 psi and there car is still running strong, like my car im boosting 20 psi spiking on the stock turbo and my car is running good, but i have the a/f right, if you run high boost and your too lean then you will have problems, thats a good little setup your trying to buy i would go that route if i were you but just like dusty said watch out with warranty and get it done right, good place to look for good prices is modernperformance . com
Old Oct 28, 2006 | 02:39 PM
hozay@N2MB's Avatar
hozay@N2MB
Default RE: Stage 1
If your looking to go cheap, I'll make it easy on ya... There's a local guy in my area selling a 05 stg 1 pcm used for $300 shipped. You can either have your local dealer flash it for you or send it out to Flight Systems & for $25 they will flash it for you.
As for a wga/mbc combo, pick up a Kinetic set. Brand new, the kinetic wga is $105 and the mbc is $55. You have all three available parts for under $500 shipped to your door.
If your not looking to "tune" or tweak anything, save your money and invest in the stg 2 WITH toys kit. Don't waste your money on stg 2 w/out toys. That's like buying a PS2 with no controller.
Old Oct 28, 2006 | 02:44 PM
MEandmySRT's Avatar
MEandmySRT
Default RE: Stage 1
ORIGINAL: manninej
I was just thinking, am I better off just saving a few hundred more bucks and get the Stage 2 w/o toys?
That's what I did - ordered S1 and within 24 hours I had the order upgraded to S2.
Old Oct 28, 2006 | 10:25 PM
05SRTStage3's Avatar
05SRTStage3
Default RE: Stage 1
Yeah Modern Performance or lethal performance....if you contact lethal by phone they will cut you a deal I got a sweet deal on my Stage 3....just call them and talk to them
Old Oct 28, 2006 | 11:38 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Stage 1
....and get some extra "Tone Rings" while you're at it................
Dusty
Old Oct 29, 2006 | 01:52 AM
05SRTStage3
Default RE: Stage 1
Incase noone knows the "tone ring" is a metal ring with 2 bolt holes and it looks like a saw blade with teeth on it....and it lines up your camshafts with your crankshafts!!!!.......It costs about $20.....but if it breaks it WILL cause alot of problems
Old Oct 29, 2006 | 03:40 AM
hozay@N2MB's Avatar
hozay@N2MB
Default RE: Stage 1
tone rings? [&:]
Old Oct 30, 2006 | 03:56 AM
slysliknwiked's Avatar
slysliknwiked
Default RE: Stage 1
you will need an a/f gauge, one of the most common and accurate ones out there is the AEM one.
ORIGINAL: manninej
