Boost Problems
Old Nov 10, 2006 | 05:00 PM
Lardass's Avatar
Lardass
Default Boost Problems
When I'm at a lower RPM and I get on it a little my boost shoots upto 15 and drops and keeps going upto 15 and then back down rapededly. But if im at a higher RPM or am getting on it from the lonch it doesnt do this to me. If anyone one can help me out it would be sweet. If it helps I have IC piping, HKS BOV, cold air, solid motor mounts and trany mount.
Old Nov 11, 2006 | 08:03 AM
talisman's Avatar
talisman
Default RE: Boost Problems
Hmmmmmm,,,,,,let me guess,,,,,is it going up to 15 each time you shift then dropping back then going to 15 again when you shift ?
No ?
Got a turbo boost leak somewhere ?
Are you sure you even drive an SRT 4 ? With a name like that you can't fit in the front seat can you ?,,,,,,,,,,,,,lol,,,,,,,j/k
Old Nov 11, 2006 | 05:28 PM
PSI Chick's Avatar
PSI Chick
stop flooring it from a low rpm and it won't be a problem. you shouldn't be doing that anyway.
Old Nov 11, 2006 | 05:39 PM
hozay@N2MB's Avatar
hozay@N2MB
^ Ding Ding Ding
Old Nov 11, 2006 | 08:53 PM
black4's Avatar
black4
what amy said.
Old Nov 13, 2006 | 12:43 PM
Lardass's Avatar
Lardass
Im not flooring it when its happening. Im at about half throttle.
Old Nov 13, 2006 | 06:19 PM
OCsrt4's Avatar
OCsrt4
This problem i had aswell at 1/4-1/2 throttle. what happens is your boost spikes and blows out the spark at low rpm, the plugs dodge used feel like they are the wrong heat range. get a set of NGK iridium plugs and a new set of MSD wires and this problem will go away
Almost entirely. Also If you know you want to get into it alittle just down shift to bring your r's up and you wont sputter. Hope this will help.
Old Nov 30, 2006 | 11:07 PM
Lardass's Avatar
Lardass
OCsrt I forgot to thank you. Im working on the things you said. Thank You.
Old Dec 1, 2006 | 05:32 PM
OCsrt4's Avatar
OCsrt4
No Problem, If you ever have questions just hit me up!
Old Dec 3, 2006 | 04:26 AM
71RoadRunner's Avatar
71RoadRunner
Get the MSD wires, the Mopar Performance plug wires, while being slightly better than stock, are far from what the MSD's are. This alone should cure your problem if it's a spark issue, unless the plug gap is too wide and causing the problem and even then the MSD wires might let enough spark energy through to stop your problem.
