19 PSI
Old Jul 24, 2004 | 04:48 AM
bigddy9's Avatar
bigddy9
Default 19 PSI
I have recently found that I'm getting anywhere from 17 to 19 PSI under certain circumstances. In 4th or 5th gear, at about 1200 RPM, if I floor the throttle, I can watch the boost gauge sweep over to 17 to 19 psi (depending on the weather). Anyone else seen this in their cars? All I have done is the BOV, nothing else. I will try to get a pic of the gauge while it happens, if I remember to take my digital camera in the car with me.
Danny
Old Jul 24, 2004 | 08:24 AM
Gump's Avatar
Gump
Default RE: 19 PSI
how are u that low rpm in those gears?
Old Jul 24, 2004 | 12:03 PM
71RoadRunner's Avatar
71RoadRunner
Default RE: 19 PSI
It's easy, I do it all the time when I come upon someone going too slow.[sm=smiley2.gif] At 1,500 RPM in 4th and 5th gear and flooring it, it has to fall on it's face until it hits 2,500-3,000 at least.
Old Jul 24, 2004 | 06:26 PM
t0973mf's Avatar
t0973mf
Default RE: 19 PSI
That's a lot of PSI for stock. Should be about 12. Check all hose clamps for leaks.
Old Jul 24, 2004 | 07:51 PM
roachnigga's Avatar
roachnigga
Default RE: 19 PSI
Yeah, B-9. Check for leaks. I have a stage 2 and i get 17-19 psi's @ 5200 rpm's @ high gear! Shoot, if there's only a BOV, i want ya mechanic
Old Jul 24, 2004 | 09:30 PM
Gump's Avatar
Gump
Default RE: 19 PSI
wouldnt it work better to down shift to the right gear for the speed?
ORIGINAL: 71RoadRunner
Old Jul 24, 2004 | 10:13 PM
andybuzz2u's Avatar
andybuzz2u
Default RE: 19 PSI
Can you say sudden death....Cause thats what your doing to your motor. You can be going 35 in fifth and floor it and the boost gauge will hit 30psi, it back fires and pops the bov to release the charge. Your computer thinks it pushing a brick wall....do your car a favor down shift and stomp it...it will love you more.
Old Jul 24, 2004 | 11:16 PM
bigddy9's Avatar
bigddy9
Default RE: 19 PSI
It's easy, I do it all the time when I come upon someone going too slow. At 1,500 RPM in 4th and 5th gear and flooring it, it has to fall on it's face until it hits 2,500-3,000 at least.
71RR, is yours hitting that much PSI too? I was actually a little concerned about it. I don't want to blow the head gasket on a 6 month old car, so I haven't done it much since I noticed it was happening. That is exactly the situation I was in when I noticed it. I was driving at about 40 mph in 5th gear and I came up on a slower driver, when they moved over, I just floored it and didn't downshift. I wonder if I should take it to the dealer and have them check all the connections to make sure there are no air leaks anywhere.
Danny
Old Jul 24, 2004 | 11:18 PM
glhs837's Avatar
glhs837
Default RE: 19 PSI
Yep, what andy and other said, it's not ggod for the car, and there is no call for it. If you are hammering the throttle at that RPM you are NOT driving it properly. Be nice to it Read your owners manual, it gives suggested shift points for maximum performance. Page 87.
Old Jul 25, 2004 | 05:13 AM
71RoadRunner
Default RE: 19 PSI
ORIGINAL: gump
It does and I do. I was just saying that I have been in those gears at that RPM before and it was usually from coming up on slower traffic, I downshift all the time though.
No. Mine gets between 13-15 PSI boost max. I've never tried flooring it at that low an RPM, I come close though but it's in first gear at the time and it spools up damn quick. You may have a leak if your getting 19 PSI or it could just be from it trying it's best to meet your demands at such a low RPM causing it to spike up so high.
