problem with strut tower bar, anyone else encountered this?
Old Dec 4, 2006 | 02:18 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default problem with strut tower bar, anyone else encountered this?
The dang bar broke off the stems of my winshield washer jets. should i get aftermarket ones that might fit better or shave down the stockers???
Old Dec 4, 2006 | 02:33 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: problem with strut tower bar, anyone else encountered this?
What brand did you have? Mine is MPx and has been problem free..........
Dusty
Old Dec 4, 2006 | 05:30 AM
PSI Chick's Avatar
PSI Chick
mine have always rubbed. i just put some electrical tape around the fitting and it's been fine.
Old Dec 4, 2006 | 11:17 PM
flamingpinhead
Section Moderator
ill have to check this some other way than shutting my head under the hood, but it seems to look as if the bar was 'pulling' on the hoses a bit?!? i dunno, may have to pull it off and just put a different one on. Im sure the mopar clears fine, but its kinda expensive. ill go look at the mpx
Old Dec 5, 2006 | 12:57 AM
71RoadRunner's Avatar
71RoadRunner
I too have the MPx and it's fine and very affordable. I would have bought the more expensive DC CS-2, but I didn't like the way it looked like it would block the hood scoops air, but it's what I have on the rear.
Old Dec 5, 2006 | 01:08 PM
flamingpinhead
Section Moderator
looking at the picture on modernperfomance, it looks just like the one on mine. i bought it off ebay and im not sure if its an MPx or not, but looks like it might be. perhaps its the hoses getting pulled agains the bar?
Old Dec 5, 2006 | 02:11 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Damn...well speaking of STB's, I'm getting both front and back DC's for 130 shipped. I love used parts!
Old Dec 5, 2006 | 05:14 PM
Plan B's Avatar
Plan B
I have the DC front strut bar. I had to rerun the hose through the middle of the strut bar (actually a two bar construction) for it was pulling the clips out when I opened the hood. Haven't had a problem since.... Maybe run the tubing up and over your strut bar?
