Old Dec 5, 2006 | 05:08 PM
Kartman38's Avatar
Kartman38
Default ???
I dont have any mods yet, but Iv heard things about the stock bov, im not goin to run any higher boost, but is this thing really gettin the job done or should I upgrade.. Plus I think im goin to put a cai on, do i need to like have the car programmed for it in any way or can i just bolt it on and go???
Old Dec 5, 2006 | 06:24 PM
prpaster's Avatar
prpaster
Default RE: ???
The Intake you can just bolt on and go. Or just unhook the battery for a few minutes to reset the computer. and the stock surge valve is ok. If you dont plan on running anymore boost then i would just leave it how it is.
Old Dec 5, 2006 | 06:43 PM
Kartman38's Avatar
Kartman38
Default RE: ???
thanks.. i appreciate it
Old Dec 5, 2006 | 07:42 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: ???
Getting an aftermarket BOV helps if the levels are higher than stock. If not it doesn't make a huge difference. But some of us are major ricers and we love the noise. Scaring pedestrians with your BOV is priceless.....people on bicycles is even better.
Old Dec 5, 2006 | 11:02 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: ???
if you want a little more noise you could consider the blue plate. and when you install the cai youll be removing your battery anyways, so the computer should be reset
Old Dec 5, 2006 | 11:14 PM
Kartman38's Avatar
Kartman38
Default RE: ???
Ya.. thanks.. i dont want somethin real aggressive.. i think il just go with the mopar kit.... i was drivin earlier and my boost like spiked to 13 which isnt bad but it usually goes to 15. Is this just due to the colder weather.?? it still goes down to 20 vac at idle, so am i just wondering about nothin?? would replacing the stock plugs and wires help that out any also???
Old Dec 6, 2006 | 01:24 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: ???
The air temperatures will have an effect on your boost level and is nothing to worry about, it drops some when it gets cold out and goes back up summer returns. Definately chuck the stock plug wires for the MSD wires, they are better in every way. Your stock plugs are fine unless you go doing alot of power modifications.
Old Dec 6, 2006 | 01:55 AM
Kartman38's Avatar
Kartman38
Default RE: ???
thanks much
